Where to buy AN-R Header. Or similar. B Series.
Old Dec 2, 2004 | 06:07 PM
EJ8 D15Y8's Avatar
Default Where to buy AN-R Header. Or similar. B Series.
Ive searched. Results for an-r are basically non existant.
Thanks.
Old Dec 2, 2004 | 06:28 PM
racecarpete's Avatar
Default Re: Where to buy AN-R Header. Or similar. B Series. (EJ8 D15Y8)
http://www.an-r.com
Old Dec 2, 2004 | 08:38 PM
DIFFUT'S INC.'s Avatar
Default Re: Where to buy AN-R Header. Or similar. B Series. (SilverCivic2k)
kteller.com
Old Dec 2, 2004 | 10:37 PM
SHystrdyGSRtdy's Avatar
Default Re: Where to buy AN-R Header. Or similar. B Series. (DIFFUT'S INC.)
did you search H-T? search recent topics, then search in post bodies then search archived then search archived with post bodies...
Old Dec 2, 2004 | 11:05 PM
ANR008's Avatar
hes right, i tried searching myself and cant find anything on us either
Old Dec 3, 2004 | 06:27 AM
EJ8 D15Y8's Avatar
How important is the merge collector on a mild motor.
Basically I/M, CTR cams and thinner HG.
Will it make the difference or will it only count on a SERIOUS build.
Also, which is better the standard or compact ?
Does the standard fit in a dc2 without mods ?
Thanks for all the help.
Old Dec 3, 2004 | 07:46 AM
n1div's Avatar
Default Re: (EJ8 D15Y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 D15Y8 &raquo;</TD></TR><TR><TD CLASS="quote">How important is the merge collector on a mild motor.
Thanks for all the help.</TD></TR></TABLE>
I would like to know this as well. Is the merge collector worth the price on a mild motor?
Have the AN-R guys done any kind of back to back testing between merge and street collectors on a mild setup? I'm curious as to the hp differences and response charateristics between the two...
Old Dec 3, 2004 | 09:18 AM
ANR008's Avatar
Default Re: (n1div)
we have seen about 4-5 whp over street collector with merge collector on mild engines. more on fully built high comp engines.
standard version will only fit with civic half size radiators.
Old Dec 4, 2004 | 06:51 AM
EJ8 D15Y8's Avatar
Any difference between the standard header and compact as far as power goe ?
Old Dec 4, 2004 | 07:46 AM
SkRiBLaH's Avatar
Default Re: (ANR008)
im selling one
robble36
May 12, 2008 05:52 PM
k24a4kid
Mar 27, 2006 03:28 PM
trick_db
May 13, 2005 09:00 PM
Crackerballer
Nov 25, 2003 01:23 AM
builthatch
Aug 19, 2003 06:46 PM
