bent part rear disc swap
Old Dec 2, 2004 | 05:02 PM
(Civic_Duty)'s Avatar
Default bent part rear disc swap
this is a 96 integra i was going to do the swap on a 92 civic then i saw this part was bent
can i use the stock civic part or a del sol w/ rear disc
Old Dec 2, 2004 | 06:42 PM
eda6's Avatar
Default Re: bent part rear disc swap (tweakedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweakedcrx &raquo;</TD></TR><TR><TD CLASS="quote">can i use the stock civic part or a del sol w/ rear disc</TD></TR></TABLE>
You can use a civic or del sol upper control arm. The delsol trailing arm would also work.
BTW If that was my trailing arm, i'd be lookin for a new one.
Old Dec 2, 2004 | 06:56 PM
Default Re: bent part rear disc swap (eda6)
so it that part a upper control arm or a trailing arm?
it is just this pice bent it un bolts from what i thought was called the trailing arm.
nothing else is bent..
so i can us my stock 92 civic cx part?
Old Dec 2, 2004 | 07:06 PM
#4 is the part i am asking about
Old Dec 2, 2004 | 07:09 PM
eda6's Avatar
#4 is the upper control arm.
The trailing arm is the arm that all that stuff bolts on to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweakedcrx &raquo;</TD></TR><TR><TD CLASS="quote">so i can us my stock 92 civic cx part?</TD></TR></TABLE>
yes
Old Dec 2, 2004 | 07:11 PM
thanks man
GuapoChapo
Apr 17, 2018 10:41 AM
EG2DelSlow
Sep 6, 2011 10:54 AM
serb_rida
Suspension & Brakes
Jun 19, 2008 04:16 PM
benjaminenjamin
27
Feb 22, 2005 03:10 PM
