Tranny Slipping . . . sort of
Old Dec 2, 2004 | 03:41 PM
H2290's Avatar
Default Tranny Slipping . . . sort of
Well I have a 2001 Honda Accord LX 4 cylinder with fagomatic transmission. The tranny seems to slip a bit right as it shifts. It is between the 2-3 shift and the revs just jump about 500 rpm before it shifts. I am thinking (wishfully) that my tranny fluid just needs to be changed after 80,000 miles of abuse and is turning to goo. Any ideas other than that? Thanks.
P.S. Don't say I need a new tranny. That would suck! But I guess if you really think that you can say it.
Old Dec 2, 2004 | 04:22 PM
philadd's Avatar
Default Re: Tranny Slipping . . . sort of (H2290)
check your tranny fluid. dab a little fluid from the dipstick onto a piece of white (preferably thick) paper. a red/pink color is good (which i'm sure you know). brown is burnt and needs to be changed. dark brown is really bad... and might be an indication of tranny wear.
most likely though, either you just need to change the fluid, or the fluid level is low. in either case, with 80,000 miles on the current fluid, you need to change it.
Old Dec 2, 2004 | 05:15 PM
H2290's Avatar
Default Re: Tranny Slipping . . . sort of (philadd)
Cool, thanks. The only car I have been worrying about lately is my 90 with the H22. I sort of neglected my 2001 after I got it. Thanks again.
Old Dec 2, 2004 | 07:19 PM
philadd's Avatar
no problem... let us know the outcome
Old Dec 3, 2004 | 02:22 AM
bill-71SS's Avatar
the trans on your 2001 has a 100,000 mile extended warranty from honda,if there is a problem,get it checked out.
Old Dec 3, 2004 | 09:51 AM
alotawatts's Avatar
Do a complete fluid flush with Honda ATF. If it still slips it could be the linear solenoid ? Easy DIY fix $150. ish ?
Old Dec 4, 2004 | 05:44 PM
H2290's Avatar
Default Re: Tranny Slipping . . . sort of (alotawatts)
Thanks for your help guys. Working 7-12s this week at work so I don't have time till next week. I'll let you guys know how it turns out. Also Bill, are you sure about that warranty. I thought it was for the V6 only.
Old Dec 6, 2004 | 02:38 PM
bill-71SS's Avatar
I work at a honda dealer,check with your dealer,it is covered
Old Dec 6, 2004 | 03:32 PM
H2290's Avatar
Default Re: Tranny Slipping . . . sort of (bill-71SS)
I will definitely do that. Thanks guys. I have not been to Honda-Tech in a long time so I'm a little rusty. Thanks again.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
phateless
Jun 23, 2009 10:39 AM
mikeintegra93
Jan 9, 2009 04:12 PM
