LS/VTEC: oil pan question
I was wondering, if you did a LS/VTEC (GSR head) would you have to also change out your oil pan? I recently bought a DC2 w/ LSVTEC and the oil pan is leaking from a tiny little crack. If the P72 oil pan has to be used on a LS block, why would it have to be used? And would it bolt right up or would you have to retro fit it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NEL1 »</TD></TR><TR><TD CLASS="quote">waht advantages would i get if i wanted to use the block girdle?
So im guessing that the ITR headers are for clearance issue. THanks btw</TD></TR></TABLE>
advantages to using a block girdle are kinda obvious..... the crank mains are held in place better with much better support.. its essential for high hp appz... i would recommend getting one and also getting gsr/type-r oil squirters if u go high hp...
Black R
Oct 9, 2006 03:03 PM
