Rocket Motorsport Vs. Toda Vtec Killer Cams
Old Dec 2, 2004 | 01:04 PM
^AnDre^'s Avatar
Default Rocket Motorsport Vs. Toda Vtec Killer Cams
How do you guys feel with Rocket Motorsports? has anyone used their cams?.. in specific the M24X, M25, or M25E ? how do they compare to the Toda Vtec Killer Cams ? any suggestions ?
Old Dec 2, 2004 | 01:11 PM
VtecKiDD's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (^AnDre^)
Would be interesting to see, but these cams are apples an oranges IMO. lets let rocket jump in here
CompressionFed's Avatar
Goodness...your looking for the big dawgs!
What are these going in?
Old Dec 2, 2004 | 01:43 PM
Tbone's Avatar
The toda vtec killer isnt a very big cam, the m24x is larger.. I ran the m24e's on the dyno and they had the most useable powerband compared to skunk stage 2's and stage 3's
Old Dec 2, 2004 | 02:05 PM
WAFFLES's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (Tbone)
do you know the vtec killer lobe specs Tony?
Old Dec 2, 2004 | 03:07 PM
Rocket's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (WAFFLES)
Run these with any VTEC cam
Something to Think About
Toda killers run off of the non-vtec "non-performance" rockers. That's no good in my book. The mid/vtec rocker is specifically designed for a bigger lobe, the non-vtec rokcers aren't.
Not for the novice since cam installation will be 25X as hard with the VTEC "on" and stiffer springs.
Old Dec 2, 2004 | 04:22 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (Rocket)
Yep, can't wait to see some dynos with those rockers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">do you know the vtec killer lobe specs Tony?</TD></TR></TABLE>
If you are talking to Tbone, his name is Tom not Tony.
Old Dec 2, 2004 | 06:14 PM
eddiecut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Run these with any VTEC cam
Not for the novice since cam installation will be 25X as hard with the VTEC "on" and stiffer springs.</TD></TR></TABLE>
who those made by?
Old Dec 2, 2004 | 06:41 PM
^AnDre^'s Avatar
the engine is a b18c5 and being put in a track car.. not hitting the street at all...
so you would suggest the m24x even over the m25 and m25e ?
also where you get those rockers from and how much coin?
Old Dec 2, 2004 | 06:52 PM
EKhatch's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (eddiecut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiecut &raquo;</TD></TR><TR><TD CLASS="quote">
who those made by?</TD></TR></TABLE>
Phantom Grip.
Old Dec 2, 2004 | 08:57 PM
UncleD's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (EKhatch)
Oh wow, these are some big fellas that I didn't even know about. Can Rocket release the specs on the m24/m25 line?? Usable compression rate?? BUMP
Old Dec 2, 2004 | 09:01 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Phantom Grip. </TD></TR></TABLE>
i hope those are as good as the lsd.....
Old Dec 2, 2004 | 09:03 PM
eddiecut's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
i hope those are as good as the lsd.....</TD></TR></TABLE>
hella_jdm, get outta this forum!!!!! hahahahha, go back to boost! lol jk
Old Dec 2, 2004 | 09:04 PM
EKhatch's Avatar
Is this sarcasm? Seriously, I am not all that familiar with their LSD but it seems people have had mixed results form it?
Thanks
Old Dec 2, 2004 | 10:48 PM
SHystrdyGSRtdy's Avatar
LOL
Thanks
if you searched, the majority says it doesn't work..
Old Dec 3, 2004 | 12:01 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (SHystrdyGSRtdy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHystrdyGSRtdy &raquo;</TD></TR><TR><TD CLASS="quote">if you searched, the majority says it doesn't work..</TD></TR></TABLE>
It works, but only for a short time. Seems to lose its effect after a few thousand miles.
Old Dec 3, 2004 | 04:11 AM
Chillinit's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (rochesterricer)
http://www.allmotorhonda.com/t...s.htm
Old Dec 3, 2004 | 04:39 AM
BERT-O's Avatar
Thanks
I install one for a customer. Came back after a month. Ended up doing a Quaife diff instead. So, yeah, lol, mixed results.
Old Dec 3, 2004 | 04:51 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">Yep, can't wait to see some dynos with those rockers.
If you are talking to Tbone, his name is Tom not Tony. </TD></TR></TABLE>
Yes, it's true, I really am retarded.
Old Dec 3, 2004 | 06:18 AM
VtecKiDD's Avatar
THose are the phantom grip rocker arms, i have them an looking at 2 sets in my store right now along with the transmission cradle
Old Dec 3, 2004 | 07:30 AM
JDogg's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (VtecKiDD)
from what i hear PG redesigned the LSD and now they work great... in fact one guy i know cut a better 60foot w/a pg lsd in a gsr diff than he did with his quaife... swapped it after the quaife ate ****
Old Dec 3, 2004 | 07:51 AM
Rocket's Avatar
Default Re: Rocket Motorsport Vs. Toda Vtec Killer Cams (JDogg)
Re the M24e / M25e profiles are meant for big motors with 15+ CR.
I have the M24X profile that will work better on less extreme motors but still more race oriented.
Old Dec 3, 2004 | 10:26 AM
^AnDre^'s Avatar
what would be the min compression ratio for a m24x then?
also how would they stack up to the toda vtec killer cams?
its over double the price for the toda so im trying to justify that buy...
anybody have dyno results from the m24x and the vtec killers?
Old Dec 3, 2004 | 10:29 AM
Rocket's Avatar
12.5+cr.
How much are the Toda Vtec Killers?
Old Dec 3, 2004 | 10:52 AM
^AnDre^'s Avatar
off the toda website 1800 Us .. ive seen em as cheap as 1700 .. where as the rocket motorsport 900-1000...
