Shaving "A" off of the hood.
Old Dec 2, 2004 | 11:02 AM
B18ls*RAYON's Avatar
Default Shaving "A" off of the hood.
I'm removing the Acura "A" on my hood. What is the best way to fill the holes. Bondo?
fISH...
Old Dec 2, 2004 | 11:06 AM
Sour Diesel's Avatar
ummm yah bondo and then sand.
Old Dec 2, 2004 | 11:56 AM
khmboostedeh2's Avatar
Default Re: (B30M87A)
no, not bondo. fiberglass it. then sand.
Old Dec 2, 2004 | 12:10 PM
[jdm ap2]'s Avatar
weld
Old Dec 2, 2004 | 12:42 PM
MarkZeroNine's Avatar
Default Re: ([jdm dc2])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE> ding ding ding!
Old Dec 2, 2004 | 12:56 PM
endlesswinterco's Avatar
Default Re: (MarkZeroNine)
weld...then the most important thing...paint it
Old Dec 3, 2004 | 10:02 AM
Default Re: (RidinlowHatch)
I said "hood" by mistake, the emblem is on the bumper. Will this make a diff. USDM front end of 2000 Integra.
Old Dec 3, 2004 | 10:11 AM
Rtistik.'s Avatar
Default Re: Shaving "A" off of the hood. (B18ls)
weld
but if you're poor like me, black tape for my black car
Old Dec 3, 2004 | 10:12 AM
TRD MA70's Avatar
Default Re: (B18ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ls &raquo;</TD></TR><TR><TD CLASS="quote">I said "hood" by mistake, the emblem is on the bumper. Will this make a diff. USDM front end of 2000 Integra.</TD></TR></TABLE>
hood= weld, bumper= fiberglass
Old Dec 3, 2004 | 10:13 AM
zanthrax's Avatar
Ruff up the inside of the bumper, put in a fiberglass matt, fill the holes with resin, paint.
Old Dec 3, 2004 | 10:40 AM
Default Re: (zanthrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax &raquo;</TD></TR><TR><TD CLASS="quote">Ruff up the inside of the bumper, </TD></TR></TABLE>
Can you explain this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax &raquo;</TD></TR><TR><TD CLASS="quote">put in a fiberglass matt, fill the holes with resin, paint.</TD></TR></TABLE>
What kind of resin? Where can I get it? B18ls=DIY
fISH...
Old Dec 3, 2004 | 10:48 AM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [jdm dc2 &raquo;</TD></TR><TR><TD CLASS="quote">]weld</TD></TR></TABLE>
Old Dec 3, 2004 | 11:22 AM
TurblowR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zanthrax &raquo;</TD></TR><TR><TD CLASS="quote">Ruff up the inside of the bumper, put in a fiberglass matt, fill the holes with resin, paint.</TD></TR></TABLE>
i would do that but without the resin. i would use bondo. they have bondo that is specificly made for urethane or plastic bumpers. dont use regular bondo cuz it wont stick.
Old Dec 3, 2004 | 11:37 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by [jdm dc2 »
]weld
]weld
]weld
]weld
]weld
]weld
]weld
]weld
Hey, smart guy!!! The bumper on the front of a 2000 DC2 is not metal, therefore welding will not work. You need to use fiberglass and then sand it down.
Old Dec 3, 2004 | 12:01 PM
zanthrax's Avatar
Rough it up with some low grit sandpaper.
The rough surface makes the resin soaked fiberglass stick better.
Bondo shrinks. After a few month there will be two dimples in the bumper. If the bondo doesn't let go and fall ouut completly.
Old Dec 3, 2004 | 12:22 PM
manekDC2.'s Avatar
Default Re: (TRD MA70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRD MA70 &raquo;</TD></TR><TR><TD CLASS="quote">
hood= weld, bumper= fiberglass</TD></TR></TABLE>
how the **** do you get fiber glass to stick to ABS plastic?? bondo won't even adhere to ABS plastic.. ohh man this is why i love honda-tech (no directed toward you) a bunch of know it all's..
now since its your bumper, and its OEM ABS plastic, the only thing that will stick to it is Epoxy.. now you could just expoy the holes let them dry and sand it out.. but if your baking the bumper after paint like you should you want to back the holes from inside the bumper with another piece of plastic and apoxy around it to mount it from moving.. this way when the epoxy heats up under the paint it wont push out or rise causing two little baybe cirlces that stick out..
fiber glass can be used on metal, but not urethane or abs plastic.. Fiber-Tex is a type of Bondo with fiber glass strans and hairs for extra strength in it. It is the really good bondo, its usually green instead of white or pink..
Good Luck
Old Dec 3, 2004 | 03:46 PM
TRD MA70's Avatar
Default Re: (manikgsr)
&lt;&lt;&lt; owned
solsquad27
Oct 11, 2008 04:00 AM
coupon
Jun 5, 2005 12:15 PM
Ekfoe
Mar 16, 2005 03:13 PM
delux247
Honda S2000
Feb 11, 2004 11:20 AM
02 coupe
Sep 19, 2003 03:55 PM
