where to get skunk 2 Intake Manifold
Old Dec 31, 2001 | 03:33 PM
95gsr's Avatar
Default where to get skunk 2 Intake Manifold
how much is intake manifold and where to get it from. I have 500$ bills and i was thinking Intake manifold or Hids. or something else I am going turbo soon so help me out
Old Dec 31, 2001 | 03:48 PM
1fastGSR's Avatar
New User
Default Re: where to get skunk 2 Intake Manifold (95gsr)
modacar.com
Old Dec 31, 2001 | 09:03 PM
Rhetoric's Avatar
www.jdmhondaparts.com
Its a special for 310 shipped for Gsr.
Old Dec 31, 2001 | 11:58 PM
owen_the_soyboy's Avatar
Default Re: where to get skunk 2 Intake Manifold (G S R)
yupper. and those gusy rule for Skunk2 parts cheap!
Old Jan 1, 2002 | 07:44 AM
6SPD_EK's Avatar
I would get the HIDs (6000k) before you get a skunk2 mani - you'll want that for when you get bigger cams (ITR or ?)
Old Jan 1, 2002 | 07:47 AM
SpeedMonkeyRacing's Avatar
Default Re: where to get skunk 2 Intake Manifold (owen_the_soyboy)
i got mine for 300
Jeff-
Old Jan 1, 2002 | 08:48 AM
speedymon's Avatar
Default Re: where to get skunk 2 Intake Manifold (Corporal-Jeff)
One on ebay just went for 265...Damn.
Old Jan 9, 2002 | 09:35 PM
vtecnologistB18c's Avatar
Default Re: where to get skunk 2 Intake Manifold (speedymon)
gbc had one for 290 shipped
and i missed out on that ****** deal
**** guess im waitin for nextime
Old Jan 9, 2002 | 09:37 PM
Chris's Avatar
Isnt it the same (or kockoff) of a TypeR IM???
Old Jan 9, 2002 | 10:36 PM
Cramerox's Avatar
Default Re: where to get skunk 2 Intake Manifold (Chris)
Basically... I wonder if the ITR Mani is cheaper?
Old Jan 9, 2002 | 11:18 PM
BlackB18C's Avatar
Default Re: where to get skunk 2 Intake Manifold (Cramerox)
inlinefour.com has skunk2 intake manifolds for $265, I think they're $305 shipped
Old Jan 10, 2002 | 05:48 AM
maggsgsr's Avatar
Default Re: where to get skunk 2 Intake Manifold (BlackB18C)
1 question for you moders,once i install the skunk 11 IM,will my ECU be able to run it right being its setup for the dual stage,or will i loose power till its reprogrammed?
Old Jan 10, 2002 | 07:04 AM
95gsr's Avatar
Default Re: where to get skunk 2 Intake Manifold (maggsgsr)
the ecu will not be involved i don't think. I beleive getting rid of rthe secondary runner will make you loss torque at and low and mid rpm but will be better at higher end. correct me if i'm wrong
and the skunk IM is about the same thing as the itr manifold but, with the ITR manifold you have to drill 2 holes i believe to have it fit or is it one. the skunk is a direct bolt on. correct me again
Luis
Old Jan 21, 2002 | 12:11 AM
whttyper1998's Avatar
New User
You're right on. You will spend more money with the Skunk Manifold because you will need a Type R intake and well as a Type R throttle cable and hanger.
Then you will need to dyno tune your car for max power.
Get the HID's
Old Jan 21, 2002 | 12:30 AM
threatcon13's Avatar
New User
Default Re: where to get skunk 2 Intake Manifold (whttyper1998)
depends on what u want. dont compare a skunk2 intake mani to HIDs. skunk2 intake mani will help your performance..HIDs will help u look "cool" and see better at night. dont get me wrong tho HIDs are da ..but i would be much happier w/ a skunk2 intake mani.
Old Jan 21, 2002 | 12:35 AM
New User
Default Re: where to get skunk 2 Intake Manifold (turbo01gsr)
He only has $500
$310 (manifold) $170 (intake) = $480 then he still need to get the throttle cable and hanger and a cable pulley!!!!!!!
Then if he has someone install it he will need more $$$$$$MONEY$$$$$$$
Then he will need to dyno tune the car which will cost more $$$$$$$$$$$
Old Jan 21, 2002 | 12:37 AM
Comtechgsr2000s's Avatar
New User
A friend of mine got it and ended up spending $750 for everything.
Old Jan 21, 2002 | 01:07 AM
01geeser's Avatar
New User
Default Re: where to get skunk 2 Intake Manifold (Mugenblkgsr2000)
damn thats bank
Old Jan 21, 2002 | 07:07 AM
JCushing's Avatar
Default Re: where to get skunk 2 Intake Manifold (vtecnologistB18c)
i got in on that deal 290 shipped......
wound up costin me 330 (the cost of im gasket and tb gasket) but then i have a b18b
[Modified by JCushing, 11:10 AM 1/21/2002]
Old Jan 21, 2002 | 10:35 AM
Big Ed's Avatar
You obviously have never seen the difference in intesity between our stock halogens and the HIDs, the HIDs make a world of difference and our worth every penny IMO, definately a purchase you won't regret. They did make a vast improvement as far as being able to see better at night, but unfortunately I didn't feel any cooler after installing them .
LS94tegra
Dec 8, 2013 03:49 AM
DelSol_F20B
Aug 7, 2009 06:19 PM
import-tooner
Feb 24, 2004 08:45 PM
b18bEG
Sep 10, 2002 06:39 PM
