Civic disc brake conversion question???
Old Dec 2, 2004 | 07:16 AM
civicturbo22's Avatar
Default Civic disc brake conversion question???
Does anyone know if a 94-01 integra rear brake disc assembly will bolt up to a 97 civic EX. If not what will? Are there any modifications necessary if it does bolt up? Also does anyone know if I would have to do anything to the breaklines? Can I use the same ones on the car or the ones that come with the teg assembly?
Modified by civicturbo22 at 10:25 AM 12/2/2004
Old Dec 2, 2004 | 07:37 AM
Default Re: Civic disc brake conversion question??? (civicturbo22)
No one knows the answer to this. Some one with any knowledge please let me know. bump
Old Dec 2, 2004 | 07:55 AM
snatch's Avatar
There are threads all over this board about this. Search for it, and I guarantee you'll find it.
edit: I searched for you
https://honda-tech.com/zerothread?id=426445
Old Dec 2, 2004 | 08:03 AM
Default Re: Civic disc brake conversion question??? (******)
No help! that is y i posted this thread. Tells the how too's but not the conversion match I am looking for.
Old Dec 2, 2004 | 08:12 AM
snatch's Avatar
If you're looking for something that tells you how to swap 94-01 Teg brakes onto a 96-00...look no further. That is basically the same. Suspension between 92-95 and 96-00 is no different. Follow the directions for that swap...92-95, and you'll be fine.
If there's something else you're looking for, let me know.
Old Dec 2, 2004 | 08:13 AM
mattssi's Avatar
I know that the 99-00 si rear trailing arms will work, not sure about the integra/civic trailing arms from those body styles. But upon close inspection out of the car from both, it appears that they would. You would just have to replace the e-brake cables. Anyone car confirm this chime in. This is just visual inspection.
Old Dec 2, 2004 | 08:35 AM
. o 69 o .'s Avatar
Default Re: Civic disc brake conversion question??? (mattssi)
trailing arms are interchangable, the rear lower control arms are not.
Old Dec 2, 2004 | 09:00 AM
Cool, thanks alot man!
hondacl9
Northeast (Sales)
Sep 27, 2012 10:15 AM
ef.91
Oct 13, 2011 11:22 PM
HogNutz
Mar 9, 2005 07:12 AM
Bob_Digi
Aug 22, 2003 08:03 AM
MugenHonda
Jun 12, 2003 05:14 PM
