i need help with wiring a 5 inch monster tach
Old Dec 2, 2004 | 06:48 AM
HondaCivicSiR1's Avatar
Default i need help with wiring a 5 inch monster tach
what do i have to do to get it to work i have a 90 dx hatch with a b16a1
any info would be better than none thanks
Old Dec 2, 2004 | 06:53 AM
mrspeaker's Avatar
Default Re: i need help with wiring a 5 inch monster tach (HondaCivicSiR1)
Red wire is Ignition Power
Black wire is Ground
White wire is Dash Illumination
Green wire is RPM Signal ..For this lots of people splice into the wire on the distributor...Anyone know if there is another place to get a rpm signal???
Old Dec 2, 2004 | 07:09 AM
d15civ's Avatar
Default Re: i need help with wiring a 5 inch monster tach (Mrspeaker)
you can tap into a wire off ur ECU for a rpm signal..
i just dont kno which pin it is..
i had my old tach set up this way before i bought my si cluster
Old Dec 2, 2004 | 08:17 AM
kaoss_11's Avatar
B A N N E D
on the blue wire connected to the dizzy thats ur rpm signal i believe
Old Dec 2, 2004 | 08:25 AM
d15civ's Avatar
Default Re: (kaoss_11)
correct.
watch out which blue wire you try and splice tho.. i can't remember on the 88-91 engines, but i kno with the d15b now, if you try and follow the blue wire, it comes out around the back and then there are 2 blue wires, so follow closely..
Old Dec 9, 2004 | 10:54 AM
92egmonkeyb's Avatar
what blue wire do i tap into under the dash if there are two
Old Dec 9, 2004 | 10:59 AM
hatchlessrex's Avatar
couldn't you use the tach signal in the wiring harness for the gauge cluster?
Old Dec 9, 2004 | 11:06 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: i need help with wiring a 5 inch monster tach (hatchlessrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchlessrex &raquo;</TD></TR><TR><TD CLASS="quote">couldn't you use the tach signal in the wiring harness for the gauge cluster?</TD></TR></TABLE>
Yes, ECU RPM signal is where mine is hooked up to.
5 inch Monster tach = +10HP
Old Dec 9, 2004 | 11:37 AM
dr_latino999's Avatar
Default Re: i need help with wiring a 5 inch monster tach (LSVTEC 91 Civic)
How many HP is it for one of the 3.something" DEFI Tachs? Still 10?
Old Dec 9, 2004 | 12:43 PM
Vtec_TrackMan's Avatar
i thougth you just want of the positive wire(blue) for the ignition coil?
Old Dec 9, 2004 | 12:47 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: i need help with wiring a 5 inch monster tach (Vtec_TrackMan)
WTF is that like instant HP???? **** that ! as if one tach wasnt enough you need "MONSTER TACH" Stoopid ricer ***
Why dont you just go to the junkyard and find one with a tach from the same year car..like a 4 door LX ..your just gonna attract thieves with that F&F look...
Old Dec 9, 2004 | 12:55 PM
Default Re: i need help with wiring a 5 inch monster tach (julio_bOostamante)
Some of us live where thieves aren't as prevalent and if they want a car bad enough, a super-sized tachometer isn't going to change their be their baseline decision. Also, chill out, instant horsepower is used when referencing anything that may be associated with "Show Mods" (Around here called rice). Also, some of us would like to have a tach that is slightly more accurate then stock, but do not have the money for an aftermarket unit (Anything with a digital display) that displays RPM among other things. And in conclusion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">5. RESPECT Respect all users, including new ones just because you've been around doesn't give you the right to be an ***. Unless you have something constructive to add keep it to yourself. Also please respect the majority of us who have a literary education and Do NoT TyP3 LyK3 dIz yO!</TD></TR></TABLE>
Old Dec 9, 2004 | 01:10 PM
I'm a Jackass
Default Re: i need help with wiring a 5 inch monster tach (dr_latino999)
i <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Some of us live where thieves aren't as prevalent and if they want a car bad enough, a super-sized tachometer isn't going to change their be their baseline decision. Also, chill out, instant horsepower is used when referencing anything that may be associated with "Show Mods" (Around here called rice). Also, some of us would like to have a tach that is slightly more accurate then stock, but do not have the money for an aftermarket unit (Anything with a digital display) that displays RPM among other things. And in conclusion...
eh..i guess ...i rather put the money to something more useful, then again if he has spent all his money on egine mods and not ricer mods then i guess it wouldnt hurt. However, why a 5" tach...how about a smaller 3" autometer tach... and who says the stock honda tachs arent precise???
Old Dec 9, 2004 | 01:19 PM
Factory Tachometer Accuracy Findings
1) https://honda-tech.com/zerothread?id=626056
2) https://honda-tech.com/zerothread?id=667044
3) https://honda-tech.com/zerothread?id=788977
Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">The normal variance is around 200-300 RPM.</TD></TR></TABLE>
But you have to keep in my mind that this is ~normal. When parts start getting old like ours have become, inaccuracy becomes a concern.
Old Dec 9, 2004 | 03:57 PM
chucka64dr's Avatar
i would have to say that a 5 inche tach is definitly rice considering your prolly buying it so others think you have a fast car with that enormous tach "bling bling"
Old Dec 9, 2004 | 04:13 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">and who says the stock honda tachs arent precise???</TD></TR></TABLE>
I do! My factory tach sucks... Autometer will recalibrate their tachs for free if needed.
Old Dec 9, 2004 | 04:23 PM
mrspeaker's Avatar
Default Re: i need help with wiring a 5 inch monster tach (chucka64dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chucka64dr &raquo;</TD></TR><TR><TD CLASS="quote">i would have to say that a 5 inche tach is definitly rice considering your prolly buying it so others think you have a fast car with that enormous tach "bling bling"</TD></TR></TABLE>
Rice??.How is this rice to you??
Its a performance gauge wether its on a fast car or slow car..It gives an accurate reading the the engines rpm..How is that rice when its function..
Yeah I know some people put it on for the look but that doesnt make the car or product rice...It makes the owner a ricer...
people that call everything rice **** me off.......
Old Dec 10, 2004 | 06:08 AM
i dont care about how it looks or how much hp it gives you i just want to know how to hook it up and to everyone who wrote stuff the was of the topic thanks for retarded comment's and in the future i'll make sure to **** up your thread's with some stupid bull **** like it was done to me. thank you to who did try and put in some for in some for real input
Old Dec 10, 2004 | 10:54 AM
Simon Tibbett's Avatar
Dont know if someone said it but you can use the power from the clock, thats what I did in my std. it didnt have a clock but the wire is still there
Old Dec 13, 2004 | 08:57 AM
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">i dont care about how it looks or how much hp it gives you i just want to know how to hook it up and to everyone who wrote stuff the was of the topic thanks for retarded comment's and in the future i'll make sure to **** up your thread's with some stupid bull **** like it was done to me. thank you to who did try and put in some for in some for real input </TD></TR></TABLE>
i was actually just messing...funny to see it got a rise outta you though
i beleive the green wire is the RPM signal. i had one hooked up to the ECU when i had MY SAFC installed. i forget what ECU pin out it was from....
Old Dec 13, 2004 | 09:20 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">i was actually just messing...funny to see it got a rise outta you though
i beleive the green wire is the RPM signal. i had one hooked up to the ECU when i had MY SAFC installed. i forget what ECU pin out it was from....</TD></TR></TABLE>
Old Dec 13, 2004 | 09:26 AM
onePOINTsix's Avatar
IMHO the easiest place to hook it up is behind the gauge cluster, it's the blue wire on the plug thats on the drivers side and it's usually like one of the wires all the way on the last pin of the plug. This is what we did on my friend's in-dash 3in VDO tach
Old Dec 13, 2004 | 10:38 AM
I'm a Jackass
this is what i have
slimjimdanny
Jan 31, 2007 07:35 PM
civiclxb16a
Apr 30, 2005 09:37 PM
92'gsrhatch
Jun 2, 2003 06:37 PM
cw_civic
Jun 17, 2002 11:32 PM
projectcrx
May 15, 2002 10:36 PM
