Transmission fluid additive
Old Dec 2, 2004 | 06:14 AM
Pompiuses's Avatar
Default Transmission fluid additive
We all know about the syncros problems with the ITR tranny. Since I track my car a bit it's only a question of time before I'll get the same problem. So I've been thinking about ways to avoid this problem before it happens to my tranny as well.
I just came across a product, Omega 915 - Gearoil additive, which seems to be higly recomended by many people.
It's made by an Australian company and similar products have been used in industry and boat engines for many years with great results.
Anyone tried any of the Omega products?
Old Dec 2, 2004 | 06:19 AM
Bbasso's Avatar
Default Re: Transmission fluid additive (Pompiuses)
Never heard of it, do you have a link so I could read up on it?
Also... If you change your MTF every 5k miles or so It would help the tranny to last longer and might give you an inside look to what's going on...
Old Dec 2, 2004 | 06:35 AM
Pompiuses's Avatar
Default Re: Transmission fluid additive (Bbasso)
Cant find anything soild.
But search on google for: omega 915 gear oil additive
...and you get a few hits:
http://www.magnagroup.com/index.asp
http://www.omega-lubricant.com/
http://www.timbuckley-omega.ie/
http://www.omegaoil.co.kr/ao-additives.htm
Edit:
Here's the propaganda at least:
http://www.magnagroup.com/prod...5.pdf
Old Dec 2, 2004 | 08:27 AM
.RJ's Avatar
.RJ
You dont need additives.
And dont use the honda MTF junk either........ I use Motul Gear 300 and couldnt be happier with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">If you change your MTF every 5k miles or so It would help the tranny to last longer</TD></TR></TABLE>
I was changing it after every track weekend. That stuff just sucks.... street driving its ok I guess.
Old Dec 2, 2004 | 09:01 AM
Bbasso's Avatar
Default Re: Transmission fluid additive (.RJ)
98% of my driving is on street, unlike you, The track *****
besides $15 every other oil change I can handle.. and the dealer is a bicycle ride away
Old Dec 2, 2004 | 10:17 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
And dont use the honda MTF junk either........ </TD></TR></TABLE>
I thought MTF was supposed to be quite good? How is the Motul oil better than the MTF?
Old Dec 2, 2004 | 10:19 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">I thought MTF was supposed to be quite good? </TD></TR></TABLE>
If you listen to teh bandwagon ******.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">How is the Motul oil better than the MTF?</TD></TR></TABLE>
Its full synthetic, does not break down and shear like the honda MTF - which is just 5w30 motor oil with a few additives.
Old Dec 2, 2004 | 10:21 AM
Pompiuses's Avatar
Its full synthetic, does not break down and shear like the honda MTF - which is just 5w30 motor oil with a few additives.</TD></TR></TABLE>
Isn't the MTF fully synthetic?? Damn.....
Old Dec 2, 2004 | 10:23 AM
.RJ's Avatar
.RJ
Isn't the MTF fully synthetic?? </TD></TR></TABLE>
Hell no
Old Dec 2, 2004 | 10:24 AM
Pompiuses's Avatar
I use the MTF-II. What's the difference from normal MTF?
Old Dec 2, 2004 | 10:26 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">I use the MTF-II. What's the difference from normal MTF?</TD></TR></TABLE>
Ah........ I dont know what the difference is, we cant get that here in the US
That stuff i *think* is synthetic. I would keep using it
Old Dec 2, 2004 | 10:29 AM
Willard's Avatar
MTF = good for street and light track driving.
hard track driving = flush it often or use more expensive fluid.
Old Dec 2, 2004 | 12:31 PM
pyromaster's Avatar
Default Re: Transmission fluid additive (Willard)
you still use MTF don't you Will? what do you classify as 'hard track driving'?
-jeff, who has seen enough pics of will on track to think he doesn't qualify as light track driving'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">MTF = good for street and light track driving.
hard track driving = flush it often or use more expensive fluid.</TD></TR></TABLE>
Old Dec 2, 2004 | 12:34 PM
B2FiNiTY's Avatar
Default Re: Transmission fluid additive (pyromaster)
I change out the honda MTF after every 500 miles or less. That stuff just isn't that great for the track.
Old Dec 2, 2004 | 12:35 PM
DutchITR1689's Avatar
MTF II is good enough. It's an upgrade of MTF and they say (dealer) that it's synthetic. They don't have that in the US.
Old Dec 2, 2004 | 12:49 PM
Pompiuses's Avatar
Default Re: Transmission fluid additive (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">
MTF II is good enough. It's an upgrade of MTF and they say (dealer) that it's synthetic. They don't have that in the US. </TD></TR></TABLE>
I still think I'm going to use the Omega gearoil additive. Can't hurt.......
A friend of of mine has shot all his syncros in his ITR, and the car is only at 115k km. Don't want that to happen to mine (or at least I can hope )
Old Dec 2, 2004 | 12:54 PM
Bbasso's Avatar
Would any of you guys that have access to the MTF II want to ship it over here?
Old Dec 2, 2004 | 12:55 PM
How do you know it can't hurt? Wrong additive can make it worse!!!! It's possible. Maybe it's not compatible with MTF-II additives....
Old Dec 2, 2004 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Would any of you guys that have access to the MTF II want to ship it over here?</TD></TR></TABLE>
It won't be cheap. Euro = expensive. Shipping also...
Old Dec 2, 2004 | 01:00 PM
Pompiuses's Avatar
It won't be cheap. Euro = expensive. Shipping also...</TD></TR></TABLE>
Well, I don't.... But it's not that cheap and comes from a reputable company. But it's no way to know until it's been tested.
You know of other additives that actually make things worse?
Old Dec 2, 2004 | 01:09 PM
Paulnsx's Avatar
isnt redline supposed to be awesome? i know many people put it in celicas which i've been meaning to do for a while to my car.
Old Dec 2, 2004 | 01:26 PM
You know of other additives that actually make things worse?</TD></TR></TABLE>
I know that gear oils for VW or brands are not suitable for Honda. They use different additives....
You should ask Omega if it's suitable for Honda gearboxes.
Old Dec 2, 2004 | 01:32 PM
Bbasso's Avatar
hrmmm
Old Dec 2, 2004 | 01:40 PM
.RJ's Avatar
.RJ
rob - motul - hmsmotorsport.com
Old Dec 2, 2004 | 01:43 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">rob - motul - hmsmotorsport.com</TD></TR></TABLE>
Will be getting some of that after the peckerheads at acrua rebuild the rebuilt tranny.
Somewhat affordable...
thanks.
