Oil Filters
What oil filters do you guys recommend? I went to the Honda Dealer and bought some but they are the Fram made Honda filters. Where can I get the Toyo Roki filters or Filtech?
Thanks in advance!
Thanks in advance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deechiguy »</TD></TR><TR><TD CLASS="quote">What oil filters do you guys recommend? I went to the Honda Dealer and bought some but they are the Fram made Honda filters. Where can I get the Toyo Roki filters or Filtech?
Thanks in advance!</TD></TR></TABLE>
For the toyo roki, i believe if you get a s2000 oil filter it will be a toyo roki. But im not 100%sure.
A Honda Oil Filter made by FRAM, I have never heard of such a thing, usually the Honda Oil Filters I get from the dealer are blue, I just buy filters for GSR, every once in a while ill spend the extra couple $ for the HAMP filter because the dealer I go to has them. I always buy Honda Filters and use Castrol GTX 10w-30
I usually use STP filters...but they didnt have any last time i changed my oil so im using a bosch now
. I use the STP because it has more holes and theyre larger than the fram...i dont know if it helps anything but it just looks like it would flow better. And i dont use anything except castrol syntec...weight varies depending on time of year.
Yeah mine are blue too. They have a Honda stamp on the top and on the side it says manufactored by Fram.
They were 7 dollars each! I think I got ripped off, but this particuler dealer tried to pull the wool over my eyes before. Anywhere on the net the sales Honda Filters that you use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s »</TD></TR><TR><TD CLASS="quote">A Honda Oil Filter made by FRAM, I have never heard of such a thing, usually the Honda Oil Filters I get from the dealer are blue, I just buy filters for GSR, every once in a while ill spend the extra couple $ for the HAMP filter because the dealer I go to has them. I always buy Honda Filters and use Castrol GTX 10w-30</TD></TR></TABLE>
Look at the manufacture on the oil filter! Honeywell = FRAM
Your Honda dealership just have a batch of 15400-PLM-A01 Fram filters left over they're trying to get rid of. Honda doesn't carry those anymore and they're superceded by the 15400-PLM-A02 Filtech Filters now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deechiguy »</TD></TR><TR><TD CLASS="quote">So the next time I need a Oil filter hopefully it will be the good ones. I should call ahead perhaps.
Thanks for the input!
That wouldn't hurt, just tell them to check the A02 number for you. Saves you a trip.
Your welcome
Your welcome
i generally use STP filters after reading a comparo done by overboost.com. they compared internals and dimensions, and STP came out just a tick under PureOne, but I can't find those. since i'm already spending like $20+ on Mobil1 Synthetic, may as well spend the extra couple bucks and get a filter with more filtering element, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16supertuner »</TD></TR><TR><TD CLASS="quote">why does it matter which manu. makes the honda filters, if honda thinks they are good enough to put their name on, then its good enough for me. </TD></TR></TABLE>
But they changed from FRAM to Filtech so what does that tell you?
http://www.ntpog.org/reviews/filters/filters.shtml
This is one of the best reviews I have found....oh and your welcome!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeprhatch »</TD></TR><TR><TD CLASS="quote">http://www.ntpog.org/reviews/filters/filters.shtml
Good info!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman »</TD></TR><TR><TD CLASS="quote">i generally use STP filters after reading a comparo done by overboost.com. they compared internals and dimensions, and STP came out just a tick under PureOne, but I can't find those. since i'm already spending like $20+ on Mobil1 Synthetic, may as well spend the extra couple bucks and get a filter with more filtering element, right?</TD></TR></TABLE>
Purolator PureOne
I cant find them here on the West coast though! Damn good filter, and only $5.99
</TD></TR></TABLE>Good info!
Purolator PureOne
from what I recall reading last year or the year before on here, there was a filter test & the K&N won hands down on the flow rate. I prefer them as you don't need a filter wrench, you can use a ratchet, but they are like $13-$14 a piece VS the $3-$4 of a regular filter.
BTW, I use Bosch b/c they are cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">from what I recall reading last year or the year before on here, there was a filter test & the K&N won hands down on the flow rate. I prefer them as you don't need a filter wrench, you can use a ratchet, but they are like $13-$14 a piece VS the $3-$4 of a regular filter.
K&N has changed since then and now uses a different filter material that is cheaper and not as good! This info and argument was in a thread a few monthes ago.
</TD></TR></TABLE>K&N has changed since then and now uses a different filter material that is cheaper and not as good! This info and argument was in a thread a few monthes ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">
K&N has changed since then and now uses a different filter material that is cheaper and not as good! This info and argument was in a thread a few monthes ago.</TD></TR></TABLE>
hmmmm, interesting. Thanks for the correction
ive been stuck on the toyo roki s2k filter . next time i might go with the mobil 1 and see how it works . very interesting on the amsoil testing , saying it can go to 1100 miles!!!!!!!!!
