tranny to block bolt hole stripped
Old Dec 1, 2004 | 10:56 PM
GSRCRXsi's Avatar
Default tranny to block bolt hole stripped
this may or may not be the best place to post this but it feels good since everyone here knows a bit about fabrication.
ok the other day i noticed that one of the large 17mm bolts that hold the tranny to the block was loose. i tried to tighten it up and it went in but wont get tight. it gets to sitting flush with the tranny and then just spins. i at first thought that the bolt had broken off in the block but i removed the bolt and its intact. it seems to partially grab the threads with no real torque on it but it wont hold the torque at all. i can see parts of the blocks threads on the bolts threads. im sure its stripped out. has anyone had this happen? i know its not a HUGE deal since it has plenty of other support, but id rather not leave it like that. what should i do to fix this? drill out the block and retap for a larger bolt? is there anything i could do to the block to restore the threads of the same size? any help is greatly appreciated.
Old Dec 1, 2004 | 11:11 PM
wHOAlly's Avatar
Default Re: tranny to block bolt hole stripped (GSRCRXsi)
find a machine shop that does timeserts, or do it youself.
http://www.timesert.com
Old Dec 2, 2004 | 11:42 AM
GSRCRXsi's Avatar
Default Re: tranny to block bolt hole stripped (Sp00n'd Supra)
how much does the kit cost?
Old Dec 2, 2004 | 07:53 PM
wHOAlly's Avatar
like 60-80 bux depending on the size etc, give em a call
Old Dec 2, 2004 | 08:07 PM
GSRCRXsi's Avatar
thats expensive. thanks for the link though, i might give them a call.
SL0Wcrx
Aug 1, 2019 03:58 PM
jorge59la
Jun 18, 2008 02:57 PM
OrangeBoost
May 4, 2006 02:49 PM
headhunter
Feb 22, 2005 02:26 PM
GSRCRXsi
12
Dec 2, 2004 07:30 PM
