96 Civic With a B-series...what exhaust?
Old Dec 1, 2004 | 10:53 PM
NickW's Avatar
Default 96 Civic With a B-series...what exhaust?
Car: 96 civic coupe
Motor: B18B with stock header
My question is: What exhaust/CAT setup can I use? Can I just use a 99-00 si cat and exhuast?
Old Dec 2, 2004 | 02:59 AM
smart monkey's Avatar
Default Re: 96 Civic With a B-series...what exhaust? (NickW)
you would use a coupe exhaust and mod it to match the length of the ls header.
Old Dec 2, 2004 | 08:23 AM
NickW's Avatar
Default Re: 96 Civic With a B-series...what exhaust? (smart monkey)
Bump for more help.
Old Dec 2, 2004 | 02:24 PM
NickW's Avatar
Let me be more specific:
What Length test pipe should I use? Does anyone sell test pipes that have the adjustable flanges to match the exhaust up? Right now I've got the issue of my cat flange not matching the flange on the header, the hole don't line up and its ghetto rigged. I know Magnaflow exhaust come with adjustable flange test pipes, does anyone sell something similar?
Old Dec 2, 2004 | 05:04 PM
racinategra's Avatar
just get your car straight piped... but if you dont want to do that Im sure a good muffler shop can make you a test pipe with which ever flange you need. Im from SO CAL. if you are from aroud here call COCO from SUPERTUNING....number is 818 988 2335
Old Dec 3, 2004 | 10:37 AM
VTECVillain's Avatar
Default Re: (racinategra)
If you are buying a catback then buy it for the chassis. There's no sense in paying big bucks for a catback only to hack it up. Certain B series headers will bolt up the stock exhaust/cat with little or no mods. At the most you might need to have an exhaust shop make a filler piece to mate it up. Of course swapping then having a custom exhaust made is always a sure way to guarantee exact fitment.
Old Dec 3, 2004 | 05:22 PM
95allmotor's Avatar
Default Re: (VTECVillain)
Depending on your budget a custom one would get the exact fit gauranteed. Also buying a stock 99 civic Si exhaust would work will small adjustments here and there. Best of luck on it.
Old Dec 3, 2004 | 06:52 PM
C M S's Avatar
Default Re: (95allmotor)
Magnaflow is a great choice. As far as your issue goes, its going to be hard/impossible to find a complete "bolt" in system. You just need to buy a exhaust for YOUR car and have a shop mod it...
Hughie1987
Oct 23, 2013 09:40 PM
jmflyd
Mar 15, 2009 10:16 AM
hondatuner020
Jan 22, 2009 07:37 AM
orangeracer
Aug 11, 2007 10:20 PM
