WFT ???? (help)
Old Dec 1, 2004 | 08:33 PM
desert eagle's Avatar
Default WFT ???? (help)
i pressure washed under my hood and some how killed my battery. so i replaced the alternator and battery. the battery keeps dying, and it throws no battery singal on the the cluster. i've dissconnect and reconnected the whole engine harnest to ensure there were no bad connections.
also the temp needle on the cluster jumps up to red and soon as accellerate it drops down to normal. i think it something to do with the (problem above). i pulled over while it was in the red and i can hold my hand on the radiator no problem. its not runnin hot. could the temp sending unit cause this?
if you read this can you bump it ? suggestions welcome. thanks
newFitOwner
Honda Fit
May 3, 2017 08:13 PM
lalaine17
Acura TSX
Mar 18, 2008 01:09 PM
drew2
Nov 26, 2005 01:37 PM
Mr. JDM-GSR
Sep 28, 2005 06:19 AM
JM Performance
Audio / Security / Video
Nov 29, 2002 06:29 AM
