will these rings fit?
i can get my hands on a set of JE std bore pistons rings and i wanna know if these will fit directly on a stock PR3 B16 std bore. i can get em for about $40
i just got a set of brand new PR3 pistons in the mail today and the guy i baught it from already put the stock rings onto the piston. being the excited 'kid' i am, i was look n at em. i proceeded to remove the rings from the pistons so that i can gap them later on when im rebuild n my motor, but i didnt have one of those piston ring expander tools that helps u install the rings onto the piston, so i used my hands to get them out. i knew in the back of my head that i shouldnt do this and just wait to go to my friends shop and use his tools, but i was too impatient. well because of my impatientness i snapped one of the compression rings. i know im a retard! so thats why im in the need of new rings.
should i just go to honda and pick up a set of rings for just one piston? how much will that cost if anyone knows.
recap: will JE rings fit std B16 pistons and should i just get one set of OEM honda rings (price for one set of rings please (compression rings))
look n for the cheaper solution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">
look n for the cheaper solution</TD></TR></TABLE>
don't look for the cheap way out when it comes to building a motor. You can buy the ring sets individually from honda, should be like $25 or so for one piston from Len on H-T. I know they were on backorder for awhile, not sure now though.
thanks. well i know that i shouldnt cheap out the engine build process, but im not gonna use cheap knock off brand stuff. stick n with OEM or resectable companies. i only need one compression ring so i'll just take a spin over to honda tomrrow and pick one up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">thanks. well i know that i shouldnt cheap out the engine build process, but im not gonna use cheap knock off brand stuff. stick n with OEM or resectable companies. i only need one compression ring so i'll just take a spin over to honda tomrrow and pick one up</TD></TR></TABLE>
youre going to have to buy the set, all the oil and compression rings, but you can buy the sets individually, just for the one piston.
