gsr bottom b16 head
Old Dec 1, 2004 | 07:33 PM
maziospzza's Avatar
Default gsr bottom b16 head
today i was in school and my friend was talking about doing a swap with a gsr bottom and a b16 head i was just wondering what type of power that would make and if it would be good or not
Old Dec 2, 2004 | 12:28 AM
Calsonic's Avatar
Default Re: gsr bottom b16 head (maziospzza)
Well the B16A head flows better even though a lot of people seem to disagree with that. The problem is the compression will be 9.6:1 which is lower than the GSR's 10:1 compression. So if the motor is stock, then the car will be slower with the B16 head. Unless you plan on going forced induction, then it's a different story.
Old Dec 2, 2004 | 12:32 AM
LSvtec03's Avatar
Default Re: gsr bottom b16 head (Calsonic)
although the b16 head does flow better, the amount is minimal and completely unnoticeable. i've seen the flowcharts somehwere, but i could never find it again. you're better off just getting headwork done to the gsr head.
Old Dec 2, 2004 | 12:33 AM
Slain's Avatar
if your going na i'd only use the b16 head if i were using different pistons to up compression otherwise the gsr head is more than adequate
90B16aCRXsi
43
Jul 30, 2008 08:50 PM
HondaTom
Aug 31, 2005 07:59 PM
90teg
Jul 2, 2005 11:22 PM
Hatchorama
31
Jun 20, 2005 03:42 AM
EFin' Kyle
Jul 26, 2004 10:09 PM
