b16 question
i just installed a b16 in my 91 hatch i noticed that after installing everything drivers side axles doesn't look staight with vehicle sorta like at angle...is that normal or maybe need different mount kit which is best...i have some black stiff mounts...?...need help
Which motor mounts you using. The length on those mounts that will put your, "tranny hole,"*sounded dirty* out of "line" as you call it. I used Avids and they aren't a steep angle but you can tell there's an incline from the hub to the tranny....or in your case the intermediate shaft and the shaft connecting to the hub......good luck
RACING INTEGRATION
Mar 3, 2006 08:09 PM
