Gsr Problems Need Help!
Old Dec 1, 2004 | 03:12 PM
PtPuff's Avatar
Default Gsr Problems Need Help!
I am running a stock jdm 95 Gsr in my del sol. My buddies stock 97 gsr is spanking me. It idles at 500-600 rpms. I had a bad ground on the tranny and the fuse blew for the ecu could that make it go bad? Could the distributor be 180 degrees off? What can go out of tune that i might check? Plus it just sucks down the gas its worse than a hemmi, Let me know thanks
Petey
Old Dec 1, 2004 | 03:15 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Gsr Problems Need Help! (PtPuff)
Are you throwing any CEL's? (Check Engine Light) If so, what codes are coming up?
A straightforward swap shouldn't have any problems. Did you use stock GSR everything? Such as ECU, harness, etc?
Try searching/asking in the Hybrid forum. They might have something for you there as well.
Old Dec 1, 2004 | 03:22 PM
PtPuff's Avatar
Default Re: Gsr Problems Need Help! (shamoo)
No lights but that might be from the fuse blowing, I've asked 2 times in the hybrid forum no one responds. I used gsr everything exept the wireharness they are both odb1 harnesses and the gsr harness is backwards.
Old Dec 1, 2004 | 04:06 PM
jinteg730's Avatar
maybe something happened to the computer, and the vtec wont work or something
Old Dec 1, 2004 | 04:09 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PtPuff &raquo;</TD></TR><TR><TD CLASS="quote">No lights but that might be from the fuse blowing, I've asked 2 times in the hybrid forum no one responds. I used gsr everything exept the wireharness they are both odb1 harnesses and the gsr harness is backwards.</TD></TR></TABLE>
Well, I don't mean lights as in headlights, etc.
Do your cluster lights light up? The oil light, the engine light, the gauge? There is a Check Engine Light. Does that stay on after the car is running?
Old Dec 1, 2004 | 04:57 PM
PtPuff's Avatar
I smell what your stepping in, no the check engine light isn't on. I wish it was then i wouldn't have to ask stupid questions I
alex2423
18
Oct 24, 2013 09:33 AM
gsrdelslo220
Mar 15, 2008 11:56 AM
accordin 2 me
Mar 5, 2008 01:10 PM
spunky424
Jul 23, 2006 07:18 PM
PtPuff
Nov 18, 2004 08:04 AM
