How do you adjust the stiffness on Apex N1 coilovers.
I already searched and found nothing on how to adjust the softness and stiffness. As noobish as this may sound I don't know how to adjust the stiffness. Is it that allen key thing on top? I was about to sell em,but if I can adjust it a bit I wanna keep em. Any help would be greatly appreciated. Thank you. Im sorry i've posted this in tech and had no response, I figured some of you R guys would be rocking these. Thanks again.
inside of the allen key looking hole on the top of the coilovers, you adjust a allen screw that sits deep inside of that hole. The key is fairly long... a good 6-8". Clicks left and right. Hope that helps... as perverted as it ended up coming out.
Turn it all the way clock wise until it stops, that is full stiff.
13 (maybe 16) clicks counterclockwise and that is full soft.
Note it will continue to turn counterclock wise with no stop, so it is best to start full hard and count clicks counter clockwise.
Mattj
Mattj
