Loud TICKING Likea dam Diesel
Old Dec 1, 2004 | 01:33 PM
cueballsi's Avatar
Default Loud TICKING Likea dam Diesel
Well it thought my car was a little loud, so i did a valve adjustment, and it is still laud?? it is all in spec.. i know it is i did it friken 4 times........ are there things that may be warn down on the valv train to make it so loud??? i am goign to be putting in a zex cam soon.. and i heard they are loud... dam my car is goign to sound like a dam Diesel tsoon
Old Dec 1, 2004 | 02:04 PM
JDMSiGuy17's Avatar
Default Re: Loud TICKING Likea dam Diesel (cueballsi)
is it a ticking or a kind of rubbing sound? when i put my stage1s and gears in and left the timimg belt cover off the belt would rub against something i cant quite remember what. it was pretty noticeable though. once i put the cover back on the sound seemed to go away. so i am not sure if your car is ticking or rubbing but if you didnt put the timimg belt cover back on check right by the belt when the car is running to see if you hear any rubbing. Hope this helps and good luck.
Old Dec 1, 2004 | 02:20 PM
cueballsi's Avatar
hmmm thanks for the info bump for more replys
Old Dec 1, 2004 | 02:53 PM
jazz215's Avatar
i had a slight whirring sound. try probing a screwdriver around different parts of the head and listen to the other end of it, to see if you can get a better idea of where its coming from.
Old Dec 1, 2004 | 03:03 PM
mattssi's Avatar
Does the sound get progressivly louder as the rpm's climb? are you sure it is the valves. Could it be a spun rod bearing?
Old Dec 1, 2004 | 04:22 PM
FizzGiGG's Avatar
Default Re: (mattssi)
OK is this a test? Loud ticking like a diesel, hmmm could it be that you are dieseling? Knocking? Detonating? Is your timing off?
Old Dec 1, 2004 | 04:30 PM
mwieczorek43's Avatar
Default Re: (FizzGiGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FizzGiGG &raquo;</TD></TR><TR><TD CLASS="quote"> Knocking? Detonating? Is your timing off?</TD></TR></TABLE>
Hopefully this guy is wrong, but do you know what detonation sounds like?? Mine was the same-way before I got my motor tuned and running correctly.
How loud is it really?
Old Dec 1, 2004 | 04:31 PM
R-Lug's Avatar
Default Re: (mwieczorek43)
sounds like a lifter... i've experienced that b4.. tick tick tick tick goes with the engine speed
Old Dec 1, 2004 | 04:33 PM
FizzGiGG's Avatar
Default Re: (ToyHatch)
If he already adj the ROCKERS ARMS it would not be that.
$.02
Old Dec 1, 2004 | 04:34 PM
DAguyLS's Avatar
yea, sounds like a stuck lifter. Seafoam that bitch....for reelz
Old Dec 1, 2004 | 09:40 PM
cueballsi's Avatar
Default Re: (slamdcivic)
I feel i know a lot about cars.. i know it is the vavle train.. not detonation..... but what i am wondering is... what gets warn down on the valve traing to make it tick loud during idle... i remeember when i had them in tight tolerance... i couldn;t hear the dam thing run ... now... in fear of the vavles not closing al the way.. i adjusted them in the middle of the 2 tollerances.. i thnk like .007 and .009 or what ever...
Old Dec 1, 2004 | 10:47 PM
cappa's Avatar
Default Re: (cueballsi)
I had a problem in my excursion with a ticking at certian lower rpms and it turns out I spund 3 bearings. But the truck never quit or lost oil pressure. I think I drove it for 5k before I even decided to look into it.
Old Dec 2, 2004 | 06:05 AM
FizzGiGG's Avatar
Yo cueballsi, if you were running your valve lash at the minimum spec. you're absolutely fine. I've heard of people going even tighter than that, so no worries.
Old Dec 2, 2004 | 06:41 AM
spankey167's Avatar
It could be your injectors... I had a ticking noise, did a valve adjustment. Still had it. I knew i had good compression because i did it not too long ago. Did the screwdriver thing. Found out my injectors were the ones tht were making that loud ticking noise. Screwdriver trick is great
Old Dec 2, 2004 | 06:43 AM
Spade's Avatar
Default Re: (spankey167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 &raquo;</TD></TR><TR><TD CLASS="quote">It could be your injectors... I had a ticking noise, did a valve adjustment. Still had it. I knew i had good compression because i did it not too long ago. Did the screwdriver thing. Found out my injectors were the ones tht were making that loud ticking noise. Screwdriver trick is great </TD></TR></TABLE>
That's what I wsa thinking. Injectors can be some noisy suckers when they're dirty.
Old Dec 2, 2004 | 06:47 AM
Grimm's Avatar
Default Re: (cappa)
if I wanted to check to see if I was spinning, or had spun a bearing, How would I go about it? Drop the oil pan and look for?
Old Dec 2, 2004 | 06:50 AM
FizzGiGG's Avatar
Default Re: (Grimm)
Chunks, lol.
To see if you have a leaky injector you can remove the spark plugs and crank the engine, gas willl spew from the faulty injector plug hole. Make sense?
Old Dec 2, 2004 | 07:54 AM
mattssi's Avatar
Drop the oil pan and the windage tray and see if you can see anything abnormal around the rod bearings. When i have replaced spun bearings, they mostly appear to have been mushed, and will have a thin like buildup between the rod and the crank. Like a very thin piece of metal. Also look for material in your oil pan after draining the oil.
Old Dec 2, 2004 | 08:56 AM
Turbo E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cueballsi &raquo;</TD></TR><TR><TD CLASS="quote">Well it thought my car was a little loud, so i did a valve adjustment, and it is still laud?? it is all in spec.. i know it is i did it friken 4 times........ are there things that may be warn down on the valv train to make it so loud??? i am goign to be putting in a zex cam soon.. and i heard they are loud... dam my car is goign to sound like a dam Diesel tsoon </TD></TR></TABLE>
are you 100% sure you did it correctly?
ive done it wrong b4 and i was positive i did it right. checked the manual...you guessed it, wrong!. i suck.
Old Dec 2, 2004 | 11:17 AM
cappa's Avatar
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">if I wanted to check to see if I was spinning, or had spun a bearing, How would I go about it? Drop the oil pan and look for?</TD></TR></TABLE>
Yea just pull the pan down and the wind tray. I would even pull the caps off the rods and mains while you were under there. That is if you don't see anything in the oil pan or the oil itself. If you are going to take the pan off what is one more step to be 100% sure if its the bearings, just make sure you retorque to specks. Only do one bearing at a time so you dont mix up the caps or nothing falls out.
Old Dec 2, 2004 | 12:13 PM
FizzGiGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdcivic &raquo;</TD></TR><TR><TD CLASS="quote">yea, sounds like a stuck lifter. Seafoam that bitch....for reelz</TD></TR></TABLE>
Not trying to attack you or anything, but show me where an over head cam engine has lifters?
Old Dec 2, 2004 | 12:38 PM
spoonek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FizzGiGG &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to attack you or anything, but show me where an over head cam engine has lifters?</TD></TR></TABLE>
Lost motion assemblies act like lifters, they keep the vtec rocker quiet until it's being used. Sometimes they stick slightly
Old Dec 2, 2004 | 12:45 PM
EL Vap133's Avatar
Default Re: (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">
Lost motion assemblies act like lifters, they keep the vtec rocker quiet until it's being used. Sometimes they stick slightly</TD></TR></TABLE>
It happened to me on my B16, replaced it and no more noise.
Old Dec 2, 2004 | 12:57 PM
FizzGiGG's Avatar
OK, that's cool. Thanks, I'll have to look into that "feature" some more.
Old Dec 2, 2004 | 03:29 PM
DAguyLS's Avatar
yes, thats what i was referring to
