1990 camber adjustable?
Old Dec 1, 2004 | 01:06 PM
Tyson's Avatar
Default 1990 camber adjustable?
hi, wondering if a 1990 prelude has adjustable front camber, stock. upper control arm kinda looks like it does.
Old Dec 1, 2004 | 02:16 PM
BoostedB20A's Avatar
It is slightly adjustable, not much at all. The holes are oval shaped.
Old Dec 1, 2004 | 02:32 PM
Tyson's Avatar
Default Re: (BoostedB20A)
interesting. thanks.
Old Dec 1, 2004 | 03:13 PM
car_boy_16's Avatar
Default Re: (Tyson)
The ludes suspension is seriously adjustable. Yea the upper control arm has those oval-shaped holes where you can adjust it just a couple degrees, but you can take those upper control arms and weld in more metal on the end of it and elongate the adjustable holes, if you get what I mean. People on PreludePower.com have done this with good results, or you can just get the Ingalls camber kit.
The Prelude's suspension also has adjustments for Toe and Caster via Radius rod, which is real cool, most alignment shops dont even look for toe or caster adjusmtents.
ChevelleSSLS6
Mar 10, 2009 01:05 PM
Mike1995HondaPrelude
Aug 15, 2007 06:38 AM
slipstream
Aug 16, 2005 01:56 AM
..::91TEG-G2::..
May 23, 2004 01:53 PM
RineRacing
May 8, 2002 05:03 AM
