1994 Accord suspension pop
Old Dec 1, 2004 | 12:44 PM
WDW MKR's Avatar
Default 1994 Accord suspension pop
I recently started experiencing a "pop" in the front end of the car, only while turning left. This didn't start until I had the car up in the air for several hours, repainting the wheel covers. It doesn't happen everytime I turn left, only on an incline/decline, or when the turn is fairly sharp and at speed. Is this a balljoint, C/V joint... ? This is just my work car, so I'm not looking for any kind of performance upgrade. Just trying to determine if it's serious and needs addressed.
Old Dec 1, 2004 | 01:10 PM
Atheist's Avatar
Check your cv boot. I would bet that if you replaced the axle with a brand new one, it would go away. Autozone has em with a lifetime warranty for like 70 bucks.
Old Dec 1, 2004 | 01:14 PM
WDW MKR's Avatar
Default Re: (Atheist)
Thanks for the reply. That's not a bad price. Can I assume it is the driver's side?
I should also note that the "pop" only happens once. After it happens, it doesn't continue to pop while I turn or even pop when the wheel is straightened back out.
Old Dec 1, 2004 | 01:40 PM
wild.irish's Avatar
Default Re: (WDW MKR)
i would think if it's only one "pop" then it's not likely to be a CV joint. also, you said you were painting covers, so i assume you didn't even took apart all of the front suspension. still less likely to be a CV.
i would think it sounds more like a spring/shock assembly: a spring could go out of place after you lifted the car. i have a '94 lx, and i'm experiencing same "pop" in my rear suspension from time to time, only this started to happen after I installed aftermarket springs with worn-out stock spring seats (bushings). i'll replace them soon, of course, but you could check your spring seats, if they were affected by suspension hanging for a long time.
Old Dec 1, 2004 | 02:04 PM
WDW MKR's Avatar
Default Re: (wild.irish)
Thanks. Nothing on the front suspension was touched. I just removed the lug nuts to access the wheel covers.
Old Dec 1, 2004 | 02:50 PM
BaGGed HoNDa's Avatar
same thing happends to me, only its turning both directions and only with a sharp turn. it started doing it after i had to slam on my breaks to avoid hitting some old people in a caddy.
Nick
sorta2
Aug 24, 2010 12:19 PM
milkmanLCA
Feb 23, 2010 10:07 AM
dude9571
Jan 5, 2007 10:54 PM
GetAwayDriver
Aug 5, 2004 09:43 PM
vteg
Dec 24, 2002 06:37 PM
