Prelude brake calipers
Old Dec 1, 2004 | 12:30 PM
Tyson's Avatar
Default Prelude brake calipers
so 90 and 91 CRX Si calipers are different than 88-89 SI and pretty much every civic of those years and on. they happen to share the same brake pads as the Prelude S of 88-90, but not Si. So then, does anyone know if prelude Si calipers would fit on a CRX then?
Old Dec 1, 2004 | 01:01 PM
Tyson's Avatar
Default Re: Prelude brake calipers (Tyson)
hmmm.. well part numbers for the knuckles are different for S and Si. i guess thats an indication the calipers wouldnt quite be interchangable. prelude Si rotors are pretty much the same size as civic EX sedan rotors tho (1/64 bigger according to specs). so might as well just do the EX knuckle mod anyway.
interestingly, check out that upper A-arm. adjustable camber?
Old Dec 1, 2004 | 01:41 PM
SETI20's Avatar
No... you want EX knuckles, and Legend V6 calipers.
You'll have to get prelude discs redrilled at 4x100mm
Old Dec 1, 2004 | 01:50 PM
Tyson's Avatar
Default Re: (SETI20)
well, im just talkinga bout calipers anyway. but 88-91 preludes at 4x100 too, so no redrilling anyway.
tooth_dr
Suspension & Brakes
May 3, 2009 12:25 AM
90jdmda90
May 14, 2008 06:19 PM
Rob.
26
Jun 29, 2006 09:50 PM
AudioXtremes
Apr 10, 2006 04:27 AM
EK4door
28
May 17, 2004 07:45 PM
