Starter keeps going out need help!!!!
Old Dec 1, 2004 | 11:56 AM
bboy21385's Avatar
Default Starter keeps going out need help!!!!
i have a b18c1 with 11:5:1 cp. my old starter went out i got it rebuilt worked for a day then went out. could i put a type r starter on there? what could make it be going bad? please help
Old Dec 1, 2004 | 12:05 PM
sammysnakes's Avatar
Default Re: Starter keeps going out need help!!!! (bboy21385)
are you sure it's the starter? what noises is it making?
Old Dec 1, 2004 | 02:05 PM
bboy21385's Avatar
Default Re: Starter keeps going out need help!!!! (chainsaw)
it acts like there is not enough power everyonce in a great while it works. but i have tried jump starting it still didnt make a difference. the alternator and battery are both new also. it clicks sometimes and sometimes it just bearly turn the motor over. when i first put the starter on after having it rebuilt it worked but seemed like it was strugling a lot. any ideas need help quick it has been snowing really hard to push start.
Old Dec 1, 2004 | 02:17 PM
PrettyLude's Avatar
check the ignition switch also
Old Dec 2, 2004 | 12:51 AM
bboy21385's Avatar
Default Re: (PrettyLude)
wheres the ignition switch? how do you check it? sorry i am learning as i go
Old Dec 2, 2004 | 07:15 PM
PrettyLude's Avatar
ignition switch is in the steering column, when you try to start it at the ignition switch, you should get a signal at the start, check it with the test light, no signal at the starter means bean ignition switch
Old Dec 2, 2004 | 10:45 PM
vtecn8ive's Avatar
How is your battery looking? Are the connections nice and clean?
efhondaracer27
Jan 21, 2010 10:32 AM
chunk3rs
11
Jun 6, 2007 11:58 AM
EG6-SIRII
Jan 12, 2007 01:50 PM
sohctodohc
Oct 18, 2006 09:08 PM
Mavrick
Mar 4, 2006 03:49 PM
