heater probs
Old Dec 1, 2004 | 11:04 AM
h22ah's Avatar
Default heater probs
i already did a seach and really didn't find any info that helped me......what happened is the heater blower fan just stoped working.......first thing i did was hit the fan and checked the fuses....so since that didn't fix anything i put a test light into the yellow wire and to aground and it showed power........so i deceded to to a ground jump off of the motor and it kicked on showing the motor was still good.......so i tried getting a test light off of the resistor pack but nothing there.......i did give the pack a 12 power into the slot where the big red/blue wire connects and test lighted the other slots and got dimmed light from each one....each one had a different brightness....yet when i try lighting the reb/blue i get nothing......the diagram i have shows taht the red/blue should be a straight power off of the motor into the resistor pack.....but it shows another connector in line between the motor and the resistor pack.......but i can't find it......i havn't checked the switch yet b/c i really don't want to pull more of dash apart......but if i have to i will..........is there anything i'm missing on these checks???ohh i don't have a multi-meter just a rigged up test light..ohh '97 se
sorry so long........at least i didn't say
"heater dosn't work...help"
aalouie
Apr 1, 2020 05:37 PM
96civic808
Dec 13, 2015 05:35 PM
Donkeeyyy
May 29, 2011 11:22 AM
crist488
Jan 16, 2010 04:42 PM
hotimportcrx
Oct 15, 2005 11:53 AM
