all motor set up on 99gsr questions
Old Dec 1, 2004 | 09:45 AM
notmightydx's Avatar
Default all motor set up on 99gsr questions
whats up H-T all motor guy. i got a 99 gsr w/ the following mods.
skunk2 manifold,
skunk2 valves,springs,retainers, STOCK CAMS, new ones waiting install
ctr pistons, rest of bottom end is STOCK
intake,
jdm dc sport 1 piece header
test pipe, apexi world sport cat back
it put down 170 whp on a dyno jet and like 132 ftlbtq.
basically i am concerend that the motor pumped 235-230-235-215. #4 is low and i am curious should i tear into the bottom end or just replace teh rings? which would make no sense what so ever. i wanna keep the ctr's if possible and replace the rods and rod bolts...
any suggestions are greatly appreciated. thanks
Old Dec 1, 2004 | 10:01 AM
nvmyb20hatch's Avatar
Default Re: all motor set up on 99gsr questions (notmightydx)
first of all, thats not really teribly low. the piston rings arent necessarily the problem. do a leakdown test on the motor and see where the air is going. if you hear noise out the tailpipe=exhaust valves, in the intake=intake valves, pull the radiator cap and see if there is bubbling=blown gasket, pull oil dipstick and listen for whistling, if you do its the rings. that is a big job to tear down the motor, so i would definitely make sure thats what it is before you go that far. hope that helps. good luck
Shaun
Old Dec 1, 2004 | 10:04 AM
thanks. who can do a leak down test? could a speedshop do one> or maybe a ACURA dealership. again thanks
Old Dec 1, 2004 | 10:16 AM
Default Re: (notmightydx)
I'd go to a dealer because they usually have an abundance of tools. however, some speed shops probably have the equipment too. i dont know if youre familiar with the Whip Factory, theyre located in plainfield, IL. dave is the owner hes a good guy. theyre website is whipfactory.com. id recommend there or acura dealer
Old Dec 1, 2004 | 10:20 AM
i have heard of WHIP FACTORY i'll try them. or acura thanks joe
Old Dec 1, 2004 | 10:37 AM
no problem man best of luck
Old Dec 1, 2004 | 12:46 PM
NO other inputs? anyone. thanks guys
Old Dec 1, 2004 | 01:44 PM
99 TYPE R's Avatar
brand new ctr cams for sale if u want em
Old Dec 1, 2004 | 02:13 PM
THANKS but i got s2s2 w/ gears.
Rikaro
Nov 5, 2007 11:40 AM
gearhead313
55
Aug 5, 2006 06:03 AM
DShowers
May 16, 2006 08:41 AM
notmightydx
Dec 2, 2004 01:10 PM
ITR1071
May 21, 2002 07:16 PM
