camber off on one wheel
After I lowered my car, I had it aligned and the front left was 3 degrees negative. What would cause one side to be so far off when the others are perfect? I know ingalls makes a camber kit that goes to 3 degrees, but this still puzzles me.
2 owners ago, the guy went over a curb at 60 mph. The guy I bought it from said he did a lot of front end work to it, so I thought that would have cured it. I have thought that this would be the problem.
well tahts prolly it check the caster adjuster sleeve wich is on the tie rod in the middle. see if the rod is bent at all they prolly wwould have told you at the adjustment place but find out to be sure.
slow~N~low
Suspension & Brakes
May 7, 2007 10:51 PM
Cannon Man
Jul 25, 2006 06:17 PM
Ross2852
Jul 28, 2005 06:06 PM
