wanted to hook up another amp, what do i have to do?
Old Dec 1, 2004 | 07:39 AM
Giga Crusher's Avatar
Default wanted to hook up another amp, what do i have to do?
waasup guys, I have a 93 Civic Hatchback, right now i am running a pair of Infinity component speakers powered by a RF 2 channel amp with a sony head. My question is what do i need if i want to hook up another amp for a sub? i have a 8 gauge amp kit and do i have to loom another power wire to the second amp or what? also, i heard someone said if i have 2 or more amp i may need a capicitor, i saw 1 and 2 farad. what are these numbers? Thanks a lot
Old Dec 1, 2004 | 07:58 AM
fcm's Avatar
fcm
Old Fart
Default Re: wanted to hook up another amp, what do i have to do? (Giga Crusher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giga Crusher &raquo;</TD></TR><TR><TD CLASS="quote">waasup guys, I have a 93 Civic Hatchback, right now i am running a pair of Infinity component speakers powered by a RF 2 channel amp with a sony head. My question is what do i need if i want to hook up another amp for a sub? i have a 8 gauge amp kit and do i have to loom another power wire to the second amp or what? also, i heard someone said if i have 2 or more amp i may need a capicitor, i saw 1 and 2 farad. what are these numbers? Thanks a lot </TD></TR></TABLE> Run another power wire, 8ga or 4ga depending on size of sub amp, adding a cap will help, [ it only needs to be on the sub amp] and again the size, [watts] of the amp will determin the size of the cap 1 or 2 farads 94
Old Dec 1, 2004 | 03:00 PM
So i have to run 2 power wire separately? coz i dont have too much room for wires.
Old Dec 1, 2004 | 03:34 PM
EBP_SI's Avatar
Default Re: (Giga Crusher)
well you can always run a single much larger cable such as a 0awg to the back into a distribution block then from there you can branch off to your other amps. the only downfall to this is that its more money than running a single wire and you can suffer from a voltage drop on your front amp when the bass hits. its also probably gonna be tough to run 0awg if you cant run 2 8awg wires.
Old Dec 1, 2004 | 05:18 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giga Crusher &raquo;</TD></TR><TR><TD CLASS="quote">So i have to run 2 power wire separately? coz i dont have too much room for wires.</TD></TR></TABLE>There is more then enough room to run 2 8ga power wires in a 93 civic, I have evan run an 8ga and a 4ga in a 93 civic 94
Old Dec 1, 2004 | 06:52 PM
tca0bell's Avatar
Default Re: (EBP_SI)
whats the point of a cap? i heard it was just like a bandaid.
94 SIR
Audio / Security / Video
Dec 5, 2008 12:50 PM
superdat1
13
Jan 4, 2008 10:42 AM
WalkerGSR1
21
Feb 15, 2007 06:58 PM
ilikeric3
30
Sep 2, 2006 02:21 PM
vtec-outlaw
Feb 4, 2002 12:45 PM
