NEED HELP LIKE ASAP THANKS
k my brake lights are stuck on even while im driving while my car is off no matter what they are stuck on what can i do to fix this
thanks in advance
Try pulling up on the brake pedal when you're stopped and checking if that does anything. Also try unplugging the sensor see if that turns them off. Let us know...
okay, now pull the sensor off the pedal bracket and push the little pin in and out. In = brake lights off, Out = brake lights on. If this is not the case, replace the sensor, get it from any Honda of the same vintage in a scrap yard, or... the dealership... $$$ Let us know.
That should be it... I wish I had a pic. If the brake lights flash on and off when you do do the test, it simply needs to be adjusted.
(ERR Stupid Post Cap... I only have one left for the next 24h)
Edit: Never mind...this is my last one until tomorrow...
Glad to be of assistance!
Modified by CycloneBlue_1.6EL at 2:25 AM 12/1/2004
happened to my friend a few months ago...it was a bulb that blew just right to make them stay on
Give it a shot...pull a harness at a time to find the side, then each bulb one at a time until you find which one.
It wouldnt surprise me if thats what the problem was
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punku10 »</TD></TR><TR><TD CLASS="quote">See not all 04 members are dumb
glad you got it taken care of man </TD></TR></TABLE>
yea good exception for once
Tyson
May 26, 2005 03:07 PM
