Benefits...?
Old Nov 30, 2004 | 08:39 PM
^AnDre^'s Avatar
Default Benefits...?
I know you guys are going to kill me over this one.. but i'll ask anyways because I need to know.
What are the gains expected or benefits from switching to a B16 Head on a B18C5 engine.. is it even beneficiary.. useful.. or harmful?
the head i want to pick up comes with
Dh-Racing Valves
4 Angle Valve Job
Diamond Milling/Resurfacing
Custom Diamond Milling
Glass Beaded Combustion Chambers
Glass Beaded Head (Entire Head)
Line Honed Cam Journals
Dual Valve Springs
Titanium Retainers
would I be expecting some decent gains from this head on my b18c5? or would I be expecting problems swapping the heads?
Old Nov 30, 2004 | 09:36 PM
^AnDre^'s Avatar
Default Re: Benefits...? (^AnDre^)
or should I send them my head off the b18c5 ?
Old Nov 30, 2004 | 10:15 PM
mtber's Avatar
Your first problem is dh-racing.
Try portflow.com
Old Nov 30, 2004 | 10:30 PM
DEVIOUS_EG*'s Avatar
stay with the stock C5' head y0!..
Old Nov 30, 2004 | 10:32 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Benefits...? (DEVIOUS_EF*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">stay with the stock C5' head y0!..</TD></TR></TABLE>
Old Dec 1, 2004 | 09:30 AM
^AnDre^'s Avatar
ok .. i will stick with the stock c5 head.. but what exactly should I do to the head to be able to run toda c cams... outside of dual valve springs and titanum retainers
Old Dec 1, 2004 | 09:51 AM
egtype-r's Avatar
the difference between just the 2 heads is the c5 had a mild p&p thats it but if you have a complete c5 head you have better im and cams so i say keep the c5 head and get a full p&p
Old Dec 1, 2004 | 10:51 AM
PreStaged12s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^AnDre^ &raquo;</TD></TR><TR><TD CLASS="quote">ok .. i will stick with the stock c5 head.. but what exactly should I do to the head to be able to run toda c cams... outside of dual valve springs and titanum retainers</TD></TR></TABLE>
I would strongly suggest running Toda valve springs with Toda cams, although people will tell you on this site that mixing and matching Rocket springs with Toda cams and Omni springs with Toda cams is OK, but im a firm believer in using the Toda valve springs with Toda cams because of the design of the Toda spring, companys dont this on their website for no reason.
*TECHNICAL NOTE
All TODA Racing camshafts must be tuned using TODA adjustable campulleys to attain maximum performance. Valve lash for all cams is 0.2mm cold. Spec B & C camshafts require TODA valve springs. For Spec A camshafts, the following Honda/Acura valvetrain components maybe used up to 8400rpm on both the intake and exhaust side.
Also
http://www.todaracing.com/prod....html
GHOSTFACE EG
May 17, 2013 09:30 AM
chad
Jul 7, 2011 09:27 PM
EFMAN
13
Apr 10, 2006 07:49 PM
S@nt0s
21
Jan 14, 2006 07:26 AM
Mr.DC2TurBo
Dec 28, 2004 06:27 PM
