Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
adjustable rear sway bar for Civic Si's?
Old Dec 31, 2001 | 06:59 AM
YodaIsGod
Guest
Posts: n/a
Default adjustable rear sway bar for Civic Si's?
Okay, i've pretty much decided NOT to buy any 22mm bar, whether that be a ITR conversion, Comptech, or Mugen. After much thinking and researching, I really do feel, in my best intrest, that a 22mm bar is just WAY to much to go to from a 13mm stock rear sway bar.
Does anyone know of any company that makes an adjustable 19mm (or around that size) for the Civic. Three-way, four-way, infinite, ect. Just wondering who.
Thanks!!!
Old Dec 31, 2001 | 07:12 AM
krshultz's Avatar
Default Re: adjustable rear sway bar for Civic Si's? (YodaIsGod)
Not sure on the size...but I've been casually browsing http://www.sanerperffab.com/, whose ad I noticed in GRM. Seems they'll custom fabricate just about anything.
Old Dec 31, 2001 | 10:36 AM
matthewk's Avatar
I just went from the 13mm bar to the 22mm bar and it is toooooo small. I need to make a switch to something even bigger. There is still not enough oversteer. It is almost to the point of off throttle retation but not quite yet.
Old Dec 31, 2001 | 11:58 AM
YodaIsGod
Guest
Posts: n/a
Default Re: adjustable rear sway bar for Civic Si's? (matthewk)
I hope you are kidding...
Old Jan 1, 2002 | 08:04 AM
89civicdx's Avatar
I use a type-r 22 bar on the rear of my 89 civic and I would agree it ain't big enough, maybe next year I will just custom bend a 24mm one. Don't get me wrong the 22 definately works but if you think that all of a sudden the back end will be stepping out all over the place,it won't. Also if you are using a front bar(you got a hatch right?) that will deminish any kind of oversteer the 22 rear will create.
Old Jan 1, 2002 | 10:56 AM
sjasmund's Avatar
Zen Autoworks has made some custom anti-roll bars for their ITC cars... Including the one that won ARRC this year. They might be able to help. Contact them via their website at: http://www.ZenAutoworks.com
Old Jan 1, 2002 | 11:03 AM
civicrr's Avatar
Default Re: adjustable rear sway bar for Civic Si's? (89civicdx)
If you are using the 22mm bar with stock or near stock, springs, that makes sense. I would not suggest that you do that. There have been many reported cases of subframe tearing from using a big rear bar with stock or near stock rates. Depending on driver ability & preference, people are running anything from the same rates to 200lbs or more in the rear than the front. Keep in mind, that unless you are near the limit, you won't get too much lift throttle oversteer. I would also check rear alignment. If you are running the factory toe-in setting, that will definitely be fighting your ability to rotate. A little toe-out in front will help with turn down/rotation. You should also check out your camber. Rear camber (negative) should be less than front. Try about 1/2* less to start.
Old Jan 1, 2002 | 03:50 PM
johng's Avatar
I think you might be over thinking the 22mm bars' ability. I went from having no rear bar to a 13mm bar, to a 19mm bar, and finally to the adjustable Comptech 22mm bar. I like it best when it's set to the full stiff setting. I guess it depends on what you want, but I don't think a 22mm bar is too big.
$.02
RyanA
11
Jan 20, 2008 10:04 PM
YoungMoneySi
Suspension & Brakes
Apr 18, 2006 11:30 AM
biggs2.3
Nov 22, 2004 06:55 PM
EleanoR
27
Jan 21, 2003 07:45 PM
sfr4dr
20
Sep 28, 2002 12:09 PM
