QUICK QUESTION! WIRING IN A CRX SI PM6
You cant. A PM6 if for a nonvtec OBD0 engine. You could either use a vtec controller or convert to OBD1 and use a P28. Good luck. Let me know if you need any other help. My shop is in MD. Check the sig
A4 and D6 are the vtec pins for an obd1 ecu.If your obd0 pm6 was converted into a vtec ecu than the pins should be the same as a pr3 or pw0 obd0 vtec ecu.
A8=Vtec solenoid
B5=Vtec pressure switch
A8=Vtec solenoid
Magick211
Mar 8, 2005 09:33 AM
you got me on that one.
