ECU code zero? turbo d15b hatch
Ok before you all flame me for not searching I did and and still can't find the answer so here goes! I recently turboed my 94 d15b VTEC hatch and now at WOT and high rpms the cel sets and it runs like crap. After it sets it idles back and forth from 2500 to 800 rpm. I jumped the connector to try to read the code and the cel stays on and the srs light flashes. WTF?!
Any suggestions will be greatly appreciated!
are u boosting more than 5-6 lbs of boost cause if u are then your MAP sensor is prolly getting jacked up during boost. if u dont have one invest in one.. a Missing link. it goes under your map sensor so it doesnt read all of that boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer859 »</TD></TR><TR><TD CLASS="quote">Oh! No!</TD></TR></TABLE>how much boost do you run?? what turbo are you running??
ROFL... Kids this is why you are suppose to search, read, and learn before putting stuff on your car...
Your really lucky u havent blown the motor, if that is not what is wrong with it now...
go to we-todd copy shortcut, then come in here and click the insert image button. then in between the brackets ]*in here*[ you paste the link from we-todd. dont go into boost on that motor!
You need to sell your car. Either that or put it on jackstands and dont take it down until you know what your doing.
Sounds to me like your throwing a MAP code because of no knowledge. Name all your turbo parts you put on your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer859 »</TD></TR><TR><TD CLASS="quote">I have no idea what boost but turbo is TD04H.</TD></TR></TABLE>is it a greddy kit??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer859 »</TD></TR><TR><TD CLASS="quote">hey luser im doing this so I WILL learn</TD></TR></TABLE>
you are going to learn the hard way if you dont get some management for that motor.
You will learn that your motor is going to blow up, and thats learning the hard way if you keep driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer859 »</TD></TR><TR><TD CLASS="quote">no its a junkyard kit i got from eBay</TD></TR></TABLE>
ok you dont have any fuel management
Not to be an @$$, but you are going to learn the hard way. When your rod going flying thru your block.
