radiator swap
Old Nov 30, 2004 | 05:40 PM
damn_import_culture's Avatar
Default radiator swap
ok want a more efficient cooling system on a budget get a radiator and upper mount from a 92-95 civic.......... WARNINIG= you may need to modify your underskin of hood a little
Old Nov 30, 2004 | 05:44 PM
dr_latino999's Avatar
Default Re: radiator swap (damn_import_culture)
Even though this is common knowledge, at least you figured this out on your own. for you.
Old Nov 30, 2004 | 05:54 PM
Default Re: radiator swap (dr_latino999)
ok i know people on this site think im dumb but im 16 and my hatch is my first car i am learing as i go from a friend and the d16a7?'s were for my retarted friend who has a retarted crx with a cheapo loud mouth fart pipe exhaust so just so i seem un bright cut me some slack im am a honda loyalist and im learning as i go as im sure most of you did
Old Nov 30, 2004 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damn_import_culture &raquo;</TD></TR><TR><TD CLASS="quote">ok i know people on this site think im dumb but im 16 and my hatch is my first car i am learing as i go from a friend and the d16a7?'s were for my retarted friend who has a retarted crx with a cheapo loud mouth fart pipe exhaust so just so i seem un bright cut me some slack im am a honda loyalist and im learning as i go as im sure most of you did</TD></TR></TABLE>
Woah, chill kimosabe. I'm not that far out of your shoes, I only have 2 years on you. What's is with the reference of the D16A7? Don't you mean A6?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">retarted crx with a cheapo loud mouth fart pipe exhaust </TD></TR></TABLE>
That's priceless, but doesn't that describe most of the people I knew back in High School?
Old Nov 30, 2004 | 06:27 PM
mrspeaker's Avatar
I hope this another joke..
Old Nov 30, 2004 | 06:30 PM
Default Re: radiator swap (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">I hope this another joke.. </TD></TR></TABLE>
It sounds more to me like someone is just a little excited and is rambling. Usually jokes around here involve much more stereotyping of the rice "culture."
Old Nov 30, 2004 | 06:33 PM
HatchBox's Avatar
Skoobie no more...
i would hate so see a thread where he gets flammed
Old Dec 14, 2004 | 03:40 PM
tRex99's Avatar
but my question is what if you want your ac? how does it work?? can that radiator keep the motor cool enough with one fan and ac system? and with a 91 crx si would i have to solder up the old ac condensor fan line to the cooling fan on the crx or just leave it alone cause the one fan does the job?
Old Dec 14, 2004 | 03:49 PM
Crx Jimmy's Avatar
use a 90-93 integra radiator I used one and you can use the stock mounts- fits fine and double the capacity- the fans even fit if you slot one mount on the fan about 5mm
Old Dec 14, 2004 | 03:57 PM
tRex99's Avatar
Default Re: radiator swap (Crx Jimmy)
id get double the capacity but i also would lose double the room right? im looking for the eg and hoping the ac works with it because its a shorty and thick and u have so much room infornt of the headers..
Old Dec 14, 2004 | 04:04 PM
Crx Jimmy's Avatar
that radiator in my crx fit with both fans and a dc 4-1 header real real tight but it did fit- you dont really need that small ac fan when you have this big radiator it stays cool enough with just the big one and it is the same size as a stock one have you ever taken it out the top and bottom tanks on the rad are way bigger then the core the 90-93 integra one just fills those tanks all the way to the edge
Old Dec 14, 2004 | 04:46 PM
tRex99's Avatar
hmmmm that sounds kinda good but id really like to get that EG one in there so much cleaner looking. but i just need to know how it would affect the ac!
Old Dec 14, 2004 | 05:27 PM
jdmdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
That's priceless, but doesn't that describe most of the people I knew back in High School?</TD></TR></TABLE>
Dr_ Latino999 is the true kimosabe from the Honda-tech tribe of Esse locos..
I CRX I
Jan 15, 2008 08:22 AM
bravo831
Honda Civic (2001 - 2005)
Aug 7, 2007 03:27 AM
bubbleboy22
Jul 18, 2007 03:49 PM
planoguy36
Apr 6, 2006 10:05 PM
VELOCITY R
10
May 18, 2003 11:23 AM
