mcmaster elbows for manifold
what part number do you guys use when ordering SS elbows for manifolds? I bought some about 3 months ago and thought they were aroung $4.50? Is their any other places online that sells them cheaper?
steve
steve
I agree and you end up with a better product in the end as well. Most guys are on a tight budget though. Most guys can build a full race type manifold for about $150 which is why you see so many of the same thing now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg »</TD></TR><TR><TD CLASS="quote">I agree and you end up with a better product in the end as well. Most guys are on a tight budget though. Most guys can build a full race type manifold for about $150 which is why you see so many of the same thing now. </TD></TR></TABLE>
yup , and to make a mini me style you only need six bends
u guys have to remember that schedule 40 is not just stronger then other schedulles but it will also hold in heat better and therefore will give you more eficiency out of your manifold.
yes it is a bit heavier but much better quallity.
But that is jus my $0.02. 98ctr
I don't really see a how a cast piece is necessarilly better quality then an extruded piece of tubing?
First thing that come to mind is porosity in the casting, sometimes a common problem on buck v8 blokc being so pourous the coolant would leak through the side of the block.
It's only stronger in relative that there is more material there, the tensile/yield strength should still be the same
just a questions is all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg »</TD></TR><TR><TD CLASS="quote">You mean it absorbs more heat right?? I think you have it backwards.. The only benefit is the cost. </TD></TR></TABLE>
well what I was thinking is that heat=energy and retaining the heat inside of the manifold helps with the gases exiting at a faster rate. unless I have my phisics backwords. anyone can tell me if im wrong. 98ctr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr »</TD></TR><TR><TD CLASS="quote">
well what I was thinking is that heat=energy and retaining the heat inside of the manifold helps with the gases exiting at a faster rate. unless I have my phisics backwords. anyone can tell me if im wrong. 98ctr</TD></TR></TABLE>
the thicker the metal the more of a heat sink it acts as, it takes allot of heat to heat soak the thick walled manis, the thinwall manifolds heat soak fast so that one they heat soak they cannot absorb anymore heat thn the reast is transfred into energy, best design imho is a thinwalled mani jethotted
GuineousMaximus
Aug 10, 2015 01:04 PM
mcmaster, here I come!
