Skunk 2 Stage 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 »</TD></TR><TR><TD CLASS="quote">Anyone out there running Skunks in a 2.0 what kind of results did you get after tuning. Motor has 11.5 comp.</TD></TR></TABLE>
Really needs more compression - lots of duration on these cams.
The Car was on the Dyno for 3 runs it hit 206hp and 139 torque it still needs some more tuning. the Valvetrain was making some noise so they pulled it off to check it out.
Thanks for the reply's
that's pretty much where you should be. A friend of mine had a 2.0 lsvtec with similar jun cams and put down 208hp. I put 190 in a 1.8 12:1 compression. That was without cam gear tuning which most likely would have resulted in some more hp, tq wasn't bad at 135.
Got Milk
15
Nov 13, 2005 10:05 AM
rev-speed
63
Mar 23, 2005 09:46 PM
