H23 swap to-----H22
Old Nov 30, 2004 | 03:56 PM
Sick'Lude's Avatar
Default H23 swap to-----H22
I have a 93 honda prelude, which has an H23 motor inside of it. I just recently received my JDM H22, and i went to this mechanic guy who told ME, that i needed the Vtec wiring harness because my h23 harness was not compatible....sooo i have been reading posts, and i finally joined H-T.Can any one tell me if thats true or not.Do i just need to wire Vtec,and the NOX sensor, and or what else?
Old Nov 30, 2004 | 05:07 PM
SKDRCR's Avatar
Default Re: H23 swap to-----H22 (Sick'Lude)
Here's what you use off your old motor.
wiring harness
distributor
fuel rail
Then you have to run two wires for vtec.
There's a thread on that in the sticky's.
Sounds like the mechanic doesn't know anything
about this swap.
I'd probably take it to someone else or do it yourself
if I were you.
Good Luck
Old Dec 1, 2004 | 06:22 AM
AndyD's Avatar
Default Re: H23 swap to-----H22 (SKDRCR)
I thought 93+ Ludes were pre-wired for VTEC.
Old Dec 1, 2004 | 11:20 AM
mgags7's Avatar
Default Re: H23 swap to-----H22 (AndyD)
some are....mine wasn't its odd...i wonder what decided whether it was prewired or not.....
oh and there is no such thing as a NOX sensor, i think you are talking about the knock sensor.....
Old Dec 1, 2004 | 11:24 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I thought 93+ Ludes were pre-wired for VTEC. </TD></TR></TABLE>
whoops my bad.
He'll still need the connectors to hook up
to the vtec op switch and solenoid though
hondaaccordf23
Jun 21, 2012 08:40 PM
h22lude93
May 28, 2008 09:28 AM
92lude76
Nov 25, 2007 07:39 AM
maxxedsx
Feb 19, 2006 12:59 PM
spnbb2
Aug 5, 2004 09:35 PM
