Location of Clutch master cylinder
Does anybody know the location of the clutch master cylinder for the 4th gen prelude.
I got into the car and it wouldnt go into 1st, 2nd, 3rd, 4th, 5th or reverse withought putting up a fight. I was told it could possibly be my master cylinder or my slave cylinder needs replacement or I just might be low on Hydrolic fluid. Need some ideas on where to tackle the problem, if anybody hs any, post up.
I am worried about a leak, what are some signs to look out for.
Nick-
Nick-
How many miles on your car, how old is the clutch, when was the last time the clutch hydraulic system was bled??
If your clutch cylinder is bad, you would have a very easy clutch pedal to push down. Also, if it is leaking, you would see signs of clutch fluid on your floor mat.
If I were you, I would check the clutch fluid first (little reservoir near the brake reservoir), then I would check your tranny fluid. Post back after you check these two items.
Andy
Andy
I have a question .... my clutch is kinda stiff and when I drive other peoples cars their clutch isnt as stiff as mines. Is that a bad thing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo »</TD></TR><TR><TD CLASS="quote">I have a question .... my clutch is kinda stiff and when I drive other peoples cars their clutch isnt as stiff as mines. Is that a bad thing?</TD></TR></TABLE>
nope
nope
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
SloCivicHMM
May 12, 2003 01:57 PM
