Do I need injectors?
How can one tell if the're injectors are on max cycle duty?
I'm getting my car tuned in spring and want to know if i should upgrade the injectors before i get my car on the dyno.
here's the basic set up:
Stock gsr block
gsr head with dpr stage 6 headwork(rewelded combustion chambers, valve job, port and polish)
itr cams
full exhaust
skunk 2 im
hondata s200
Stock injectors
Any thoughts or suggestions? I've searched for injectors, and read up on them alot, I just can't decide if I need bigger ones for my set up. Right now I'm hoping to make around 190whp.
Stock gsr block
itr cams
full exhaust
skunk 2 im
hondata s200
Stock injectors
You won't need bigger injectors.
I am still on the stock ones with this setup: https://honda-tech.com/zerothread?id=1068355
and the they can still give alot more fuel than I need.
JDM turbo DC
Mar 24, 2006 05:44 PM
