Can I expect more power by boreing out the carb then buying new headers?
Old Nov 30, 2004 | 10:42 AM
hondaracin24's Avatar
Default Can I expect more power by boreing out the carb then buying new headers?
After doing a good amount of research on how to slightly increase more power into my car without spending a lot of money. Ive come to boreing out carbs. When comes to boring out a carb how much more power can you expect out of a car? I have a f22b1 v-tech.....
Old Nov 30, 2004 | 11:06 AM
1994AccordSiR's Avatar
Default Re: Can I expect more power by boreing out the carb then buying new headers? (hondaracin24)
why on gods earth do you have a carb'd 94 accord
Old Nov 30, 2004 | 11:09 AM
fw190bvi's Avatar
Default Re: Can I expect more power by boreing out the carb then buying new headers? (1994AccordSiR)
omfg....if youve got a carbed f22, then youd already probably be makling alot of power already (see bisimoto's setup)....modern engines (for the most part), arent carbed, but use electronic fuel injection...
Old Nov 30, 2004 | 03:16 PM
aznboi3644's Avatar
do you mean the throttle body and not the carb? than if so i would say it will make a little more power than stock. why do you think people buy larger diameter TB's?
Old Nov 30, 2004 | 04:46 PM
Default Re: Can I expect more power by boreing out the carb then buying new headers? (aznboi3644)
My bad everyone I meant "throttle body" not the carb. Thanks for clearing that up for me and yes my car is fuel injected. I just used the wrong wording. Sorry about that.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">omfg....if youve got a carbed f22, then youd already probably be makling alot of power already (see bisimoto's setup)....modern engines (for the most part), arent carbed, but use electronic fuel injection... </TD></TR></TABLE>
So are you saying a carb set-up could produce more power if it was bored out oppossed to fuel injected vehicles?
Old Nov 30, 2004 | 07:30 PM
v4lu3s's Avatar
RTFM
the throttle body wont he be teh biggest restriction, overboring ownt help a lot unless you ahve a lOT of other work done on teh engine.
at msot you will see very slight gains and slightly better throttle response. at worst you will lose a good idle and lose power.
Old Nov 30, 2004 | 07:52 PM
SuperSlow's Avatar
It will be a waste of time for you at this point.
hondaracin24
Oct 8, 2010 08:39 PM
Hatcheys314
Jan 21, 2010 09:07 AM
pornstar4777
May 17, 2006 04:05 AM
dominate9
Feb 4, 2004 09:32 PM
