Tap size anyone! HELP!
Old Nov 30, 2004 | 09:59 AM
nfinitecc's Avatar
Default Tap size anyone! HELP!
i need the Specs for a TAP for the six holes in the crank for the flywheel bolts, the threads broke off some in the holes, i think its a 1.75mm fine....12x1.75mm fine maybe??? the guys at napa were no help. Please help!! can i use a thread chaser maybe???
Old Nov 30, 2004 | 03:22 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Tap size anyone! HELP! (nfinitecc)
I can't tell you the size for definate, but I can tell you that there is a distinct possibility theat there will be too little material left in the holes to actually chase the threads. Chasers are meant to clean up threads that have debris in them. if you've stripped the material out of the holes, you may have actually removed material, which will comprimise their strength. Personally with a flywheel turning that many rev's I thinkI'd rather purchase a new/used flywheel, and be safe. It'll be cheaper in the long run than having to replace parts that a broken or dislodged flywheel could cause.
Clayton
Old Nov 30, 2004 | 03:27 PM
Turbo-charged's Avatar
Default Re: Tap size anyone! HELP! (Clayton)
new flywheel wont help....you would have to replace the crank.
be carefull whatever you do. my friend had a similar problem...im not sure how he went about fixing it...or if he did....but a couple weeks after he put it back together the flywheel worked its way loose and flew out the case of the transmission. pretty scarry stuff.
Old Dec 1, 2004 | 08:17 PM
nfinitecc's Avatar
Default Re: Tap size anyone! HELP! (Turbo-charged)
see thats why i think its ok, it didn't "eat" the threads up, a good bolt will screw in half way with ease by hand and the threads beyond the couple damaged are also fine...so i figure new bolts plus some thread locker will do the trick!
By the way the tap is a M12x1.00...was super hard to find..had to be custon ordered!
Old Dec 2, 2004 | 08:58 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
so did you order one/find one? cuz if not, i have that tap for flywheel bolts...yeah i had to have it made.
mattie_96
Jun 29, 2008 05:19 PM
DsVtec2nrHBC
Mar 24, 2005 07:48 PM
ef9wpb
Mar 4, 2004 08:51 PM
daniel89civ
Sep 5, 2002 06:59 PM
