anybody know another way to take of crank pulley bolt wothout an air gun
Old Dec 30, 2001 | 09:20 PM
wdyno's Avatar
New User
Default anybody know another way to take of crank pulley bolt wothout an air gun
just wondering if there was a way around getting an air compressor
Old Dec 30, 2001 | 09:47 PM
JM Performance's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (wdyno)
Not on the Teg, but w/ other cars I've used 3" long pipes. Just slip it of a socket wrench....a STRONG one.
Old Dec 30, 2001 | 10:46 PM
Mista Bone's Avatar
D Tranny Guru
A pry bar to hold the flywheel, covered in Helms manual.
Old Dec 30, 2001 | 11:12 PM
b18bvudoo's Avatar
New User
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (Mista Bone)
would that damage the flywheel? i wouldnt wanna hurt my 9 lb baby
Old Dec 31, 2001 | 09:44 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (vudoo666)
not if you read the Helms.
Old Dec 31, 2001 | 10:01 AM
JCushing's Avatar
i used to do this trick lock the flywheel of crank pully then torch the **** outa it around the bolt (not the bolt itself) then just use a 1/2 " breaker bar and a 19mm socket, sit down, hold on to the to hook in the front of the car, and push off of the breaker bar with my feet. sometimes i would have my freind hit the breaker bar with a hammer as i was doing this too. gets it off every time!!!
Old Dec 31, 2001 | 10:02 AM
Cliff Huckstable's Avatar
This has helped me in the past. Get a breaker bar or 1/2 inch ratchet along with a BFH (big ******* hammer) With the socket on the crank pulley bolt give the ratchet a couple firm hits. This of course is alot easier to do when the motor is out of the car but I has worked for me every time. Hope this helps.
You can also heat it up with a torch and that will also help quite a bit just dont set you fender lining on fire.
Old Dec 31, 2001 | 10:04 AM
JCushing's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (Cliff Huckstable)
dude why you got to copy my posts???
Old Jan 1, 2002 | 11:24 PM
wdyno's Avatar
New User
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (JCushing)
cool thanks guys.. imma go try this tomorrow
Old Jan 1, 2002 | 11:51 PM
vteg's Avatar
New User
Has anyone tried this:
http://www.thetoolwarehouse.net/shop/product5853.html
I ran across this when I purchased my valve adjustement tool. At the time this was one of Schley's new products.
Old Jan 2, 2002 | 02:30 AM
ingrate's Avatar
25 Year Member
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (vteg)
that looks pretty nifty. i might try it when i do my timing belt in about 3 years
Old Jan 2, 2002 | 08:10 AM
Mista Bone's Avatar
D Tranny Guru
check you crank pulley before buying it.
BTW does same job as the Moroso tool.
Old Jan 2, 2002 | 08:14 AM
Piston Honda's Avatar
And currently this tool is on sale at a price that is about $10-$20 cheaper than the Moroso.
Old Jan 2, 2002 | 09:47 AM
95gsr's Avatar
WELL in reading the helms it says that the bolt is 130 lbs now unless you can produce that then i dunno. i am pist cause i have to do this in an hour or so and i have an impact gun that does 75 LBS and i am doudting that it would take that
bolt off and should I replace the bolt while i'm at it or just use the same one. should i use anti seize
Old Jan 2, 2002 | 09:57 AM
VTEC4GS's Avatar
two ways:
1) taking off black flywheel cover and lock flywheel
2) 1/2" wrachet with flex joint and extension locked against chassis, push car while in gear and on the clutch pedal, then drop clutch and it'll crack.
did number 2 many times while at the track.
Greg
Old Jan 2, 2002 | 10:40 AM
95gsr's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (vtec4gs)
You know what vtec4gs you one smart son biatch. I would have never even thought of that. That is a good trick to know.
Old Jan 2, 2002 | 11:12 AM
95gsr's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (95gsr)
Now how would you torque it back down to 130
Old Jan 2, 2002 | 11:43 AM
95gsr's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (redteggy)
where is the cover to open the flywheel and what to put in there
Old Jan 2, 2002 | 01:07 PM
Big Teggie's Avatar
Just put the biggest peice of pipe you can find and put it over the breaker bar and it will come right off. I have done timing so many times, and after the first time it is easy. Muscles and a big pipe can lossen anything.
Old Jan 2, 2002 | 01:21 PM
VTEC4GS's Avatar
if you take off the bolts for the black flywheel cover, I think 2-17mm, 2-12mm and 2-10mm bolts you'll get access to the flywheel. Use a prybar to hold the teeth. Use a 1/2" breaker bar and 19mm socket to crack the crank pulley bolt, once you hold the flywheel with prybar, you can crack the bolt with a typical 1/2" drive Craftsman torque wrench... you can also torque it back with that also.
the reason why ppl think you need a long pole is because to crack the bolt the engine does spin slightly whereas if you lock the flywheel its easy as cake and doens;t take that much torque at all.
Greg
Old Jan 2, 2002 | 07:16 PM
MugenEg6's Avatar
Default Re: anybody know another way to take of crank pulley bolt wothout an air gun (sw388)
Buy the tool from honda and do it the right way
Old Jan 3, 2002 | 11:34 AM
Mista Bone's Avatar
D Tranny Guru
Hey Greg, if they read a Helms they would see these directions.
d124g0n
Oct 29, 2005 07:37 AM
shauniewalnuts
19
Dec 25, 2004 11:33 AM
Ignitecivic
Mar 20, 2004 09:41 AM
smithbling
18
May 7, 2003 06:53 AM
MCP486
Apr 1, 2003 09:48 AM
