Question: What B20b motor mounts to use?!?!?!
Old Nov 30, 2004 | 12:02 AM
jdm96dc2's Avatar
Default Question: What B20b motor mounts to use?!?!?!
i was wondering for all you b20 owners...what kinda motor mounts did u guys use or prefer? im puttin da b20 into a 96 hatchback...any help would be great...thanks!
Old Nov 30, 2004 | 08:36 AM
AlLMoToRvOtEr's Avatar
Default Re: Question: What B20b motor mounts to use?!?!?! (jdizzle00)
You will need to use either a mount kit from a company or you can use 2000 SI mounts all of them, that will prolly be the cheapest and best way to go.
Old Dec 1, 2004 | 05:18 AM
jdm96dc2's Avatar
Default Re: Question: What B20b motor mounts to use?!?!?! (AlLMoToRvOtEr)
u tink some stock ctr mounts would work?
Old Dec 1, 2004 | 05:53 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdizzle00 &raquo;</TD></TR><TR><TD CLASS="quote">u tink some stock ctr mounts would work?</TD></TR></TABLE>
Probaly wouldnt they be the same as 99-00 Si mounts? Both are B-Series
I would def recomend some Inserts atleast since the motors not even
installed yet.
Old Dec 2, 2004 | 08:58 AM
Default Re: Question: What B20b motor mounts to use?!?!?! (QUiKSR20)
Ya inserts are a good idea, the drivers side mount is a really bad design and when you have a bigger motor with them they tend to break. I would just get the polly insert for the 2 sides and the rear and the vibration mounts. Might be alittle more vibration but your motor will be solid and you won't have to worry about any movement with your motor.
alx_90ef
20
May 30, 2014 06:31 AM
hondallday
Jan 23, 2009 03:21 PM
white_db8
May 26, 2007 09:34 AM
GoCarInteg
Jul 27, 2005 11:31 AM
jdm96dc2
Dec 1, 2004 06:52 AM
