compression test results for high compression sohc vtec-
Old Nov 29, 2004 | 09:31 PM
builthatch's Avatar
MiG-21 superfan
Default compression test results for high compression sohc vtec-
i have done compression tests for some time over the course of the past year and a half and come out with about 245 across all cyls...
i did one tonight and i had 245 235 245 245...
the 10 psi diff, could that be accounted for by going a little too tight on the .004/.006 lash settings on the low cylinder when i put in the Crower stage 3 cam 2 weekends ago? i can imagine the possibility of this situation grows exponentially when you get as close as i am.
88 civic
Apr 5, 2009 03:21 PM
puma2132
Feb 8, 2009 02:37 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
