piston to deck height, alittle complicated...well for me
LS block with gsr internal. Since I de-stroked the motor, and the piston does not travel as high up the cylinder, does anyone know how to get the piston to deck height assuming stock ls pistons? with just numbers?
Well I crunched some numbers(not sure if im close) and I got a 0.109in piston-2-deck height, can anyone confirm? the stock p-2-d-h is 0.030in, and the difference between the stroke (89.00-87.20) is 1.80 so if i subtract the stroke its 1.80mm which is ruffly 0.070in so i just add it to the 0.030? and i get 0.109in p-2-d-h? is that right?
Modified by NightmareApex at 11:37 PM 11/29/2004
nytosc
Apr 24, 2009 08:38 AM
SickWitIt2.0
Dec 10, 2005 08:32 AM
