my friend is selling 310 injectors, will they fit my car???
Old Nov 29, 2004 | 08:44 PM
torqueless's Avatar
Default my friend is selling 310 injectors, will they fit my car???
My friend is selling his rc 310cc injectors, he had them in a 94 integra gsr obd1.
will they work for a 93 civic ex d16z6? tia!
Old Nov 29, 2004 | 09:13 PM
mr.beeks's Avatar
Default Re: my friend is selling 310 injectors, will they fit my car??? (torqueless)
basically the same obd1 plug injectors will fit
but do you have the ecu to control them
and the FPR also
Old Nov 29, 2004 | 10:11 PM
lightspeedsJDMDC2's Avatar
Default Re: my friend is selling 310 injectors, will they fit my car??? (mr.beeks)
yeah thell fit but the only thing u have to worry about is it dumping too much fuel and bogging out the motor. and if u run too rich it can cause a problem and blow a piston ring
Old Nov 29, 2004 | 10:50 PM
torqueless's Avatar
Default Re: my friend is selling 310 injectors, will they fit my car??? (jdmMONKY)
im not sure what you mean by "do i have the right ecu to control them, my stock one will work wont it? or do i have to get another ecu to control them?
Old Nov 29, 2004 | 10:53 PM
Sack Master's Avatar
Yeah it will work. But you'll more than likely need some way to regulate the amount of fuel going into the cylinders. I'm sure that little d16 will run pig rich if you don't. Providing its an otherwise stock motor.
car_mo_na_po
Sep 13, 2011 02:04 PM
precisionelite
Jan 13, 2007 08:03 AM
radmxracer72
Dec 14, 2005 10:27 PM
TooDrunk2See
Oct 27, 2003 06:38 PM
