AC tensioner pulley removal
Hi HT's,
I just removed my A/C compressor and belt. Is there a problem with removing the tensioner pulley and it's little but chunky bracket which is held by about 3 bolts (one of which is very long). I'm just a bit worried that its a "torque mount" that i've heard about. Or is the "torque mount" the bottom engine mount?
Cheers for any advice
i don't recommend you remove the tensioner pulley and bolt becuase then you'll have to relign the little spring back. Why are you removing the tensioner anyway?
Because I have removed the rest of my A/C and if there is no need for this part anymore it may aswell not be there and be sold with the A/C. I can't say I know what you mean about a spring though...
There doesn't appear to be a torque mount connected to any part of my air con on my d15b. Can anyone clarify this? And can the third A/C belt pulley (the small one) be removed and its bracket? (without affecting anything).
mcs5280
Aug 24, 2013 07:39 PM
MelJ
13
Dec 10, 2010 06:25 PM
vbolz
Sep 9, 2010 07:56 PM
