si cluster in ex....
Old Nov 29, 2004 | 06:40 PM
hondaracing1's Avatar
Default si cluster in ex....
is it just plug and play..i know redline on the rpm is different but would it work and how easy is it to put in
Old Nov 29, 2004 | 06:42 PM
klungemonger's Avatar
It works fine and is accurate. VERY easy to install! Take out 2 screws from cluster bezel, pop it out (2 clips hold it in at the bottom). Then remove the 4 screws holding cluster in, unplug it, and install new cluster in reverse!
EM1specR's Avatar
Default Re: si cluster in ex.... (hondaracing1)
ALL 96-00 civic clusters are plug n play interchangeable.........
Old Nov 29, 2004 | 06:44 PM
Default Re: si cluster in ex.... (EM1specR)
alright thanks guys...just hav eto get used to redline not being the same dont wanna take it too far
Old Nov 29, 2004 | 06:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks guys...just hav eto get used to redline not being the same dont wanna take it too far</TD></TR></TABLE>
Your ecu will not allow you to go farther than you did with the other tach. You are still limited to around 7000-7200 rpm regardless of what the tach says...
Old Nov 29, 2004 | 07:37 PM
xkwzt21's Avatar
Default Re: si cluster in ex.... (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">
Your ecu will not allow you to go farther than you did with the other tach. You are still limited to around 7000-7200 rpm regardless of what the tach says...</TD></TR></TABLE>
i dont think that is what he was referring too. he means that the redline on the tach is at a higher rpm than his ex tach, i think he knows he wont have a higher redline altogether.
Old Nov 29, 2004 | 07:42 PM
EK k kay's Avatar
Default Re: si cluster in ex.... (xkwzt21)
Go by the RPM, not by the red mark. When I'm smashing, in my mind it goes like this "shift at six, shift at six, shift at six" lol
Old Nov 29, 2004 | 08:36 PM
BlueIntegraBoy's Avatar
Default Re: si cluster in ex.... (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">Go by the RPM, not by the red mark. When I'm smashing, in my mind it goes like this "shift at six, shift at six, shift at six" lol </TD></TR></TABLE>
LOL, my friend does the same. I originally swap an Si tach face on an EX tach mechanism. Bad idea. Both mechanisms broke. But if done successful, the redline on the EX tach is in the same area as the Si tach, so the redline would be at 8k with a D16Y8 before hitting limiter.
Old Nov 29, 2004 | 09:13 PM
blaster834's Avatar
plug and play y0
digi198816
Mar 21, 2010 12:43 PM
triple5soul8781
Aug 7, 2008 05:46 AM
rockthegens
Aug 4, 2005 08:23 PM
Frito-Ray
Feb 15, 2005 12:12 AM
snouka
10
Dec 8, 2004 10:47 AM
