What did they do wrong?
Old Nov 29, 2004 | 06:34 PM
belkin1323's Avatar
Default What did they do wrong?
1999 Accord LX 2.3l auto. I had my timing belt/water pump replaced at 111k by a Honda dealership. My wife picked the car up and drove it to her work by the time she got there the engine light was on and it overheated. I went to look at the car and the dealership had not tightened the bleeder valve on thermostat so it lost most of its water. I started looking around and noticed that the #1 plug wire wasn't seated all of the way. When I pulled the wire I found that the sparkplug had not been tightened down. The dealership sent a wrecker and took it back to the shop and supposedly fixed the problems and said that there was no permanent damage done. I drove the car home this time and it seemed to drive fine. My wife told me the next day that something wasn't right, I drove the car and it had a sporadic miss at idle and as I would take off from a stop. The plugs had been replaced at 105k with Autolite Platinum. I called the dealership and they said that they had, had problems with these kinds of plugs. So I changed them out with Honda recommended NGK's and the problem stopped. Now 1000 miles later the miss is starting to come back. So here is my question. What could be causing the car to foul plugs? Is it a problem that is going to lead to total failure? Do you think it is the dealerships fault or a very odd coincidence? Thanks for your help!
4everVtec
12
Mar 16, 2017 02:08 PM
boostedEggs
Mar 1, 2013 06:28 PM
beantowncoupe
Nov 24, 2008 04:46 PM
metalwerker
Dec 9, 2006 02:24 PM
Jockobo
Jul 23, 2002 06:42 PM
