Valve Cover Studs
Old Nov 29, 2004 | 06:06 PM
colombian linx's Avatar
Default Valve Cover Studs
Recently one of my valve cover studs snapped while putting on a nut, i'm wondering if these valve cover studs would fit my 99 B18C1, http://www.jegs.com/cgi-bin/nc...r=361, i've searched to find out the size of the stud but couldn't find anything, also im wondering where I could buy a Vtec solenoid gasket, thanks.
Old Nov 29, 2004 | 06:11 PM
sporkcrx's Avatar
Default Re: Valve Cover Studs (colombian linx)
Bring the stud to your local hardware store, and find a nut that threads onto it nicely. Then take that same nut and find a stud there that it threads nicely on. Purchuse stud.
Old Nov 29, 2004 | 07:09 PM
GWInquisitor14's Avatar
Default Re: Valve Cover Studs (sporkcrx)
arent the studs also the bolts that hold the cam cover down?
Old Nov 29, 2004 | 07:13 PM
mmuller's Avatar
Mad Scientist
wich one did you break?
i dont think the studs in the link you posted are the right thread.
get them from the dealer
Old Nov 29, 2004 | 07:35 PM
the one that hold the cover down the ones next to the spark plug wires there is 4 around it
Old Nov 29, 2004 | 07:39 PM
mmuller's Avatar
Mad Scientist
Default Re: (colombian linx)
you need the honda dealer for those.
contact LEN here on h-t
http://www.acuraautomotiveparts.org/
http://www.hondaautomotiveparts.com/
Old Nov 29, 2004 | 07:54 PM
on that image which number is the bolt i cant seem to find it, is it number 19??
Old Nov 29, 2004 | 07:55 PM
IN VTEC's Avatar
Those studs from Jeg's are not metric thread.
Just order a new bolt-stud from your local Honda/Acura....or you can order it from Baranco.
90014-PR3-000
It should be about $4 to $5.
The bolt isn't on that image. It's listed under CYL HEAD b/c it doubles as a bolt for the cam cap rail.
Old Nov 29, 2004 | 08:00 PM
im also looking for the vtec solenoid gasket is it number 14 on that display??
and the bolt is # 20 right?
Old Nov 29, 2004 | 08:10 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by colombian linx &raquo;</TD></TR><TR><TD CLASS="quote"> im also looking for the vtec solenoid gasket is it number 14 on that display??
and the bolt is # 20 right?</TD></TR></TABLE>
yes as far as the bolt and for the sol. gasket, is that the one that you need? or you need the spool gasket? #12?
Old Nov 29, 2004 | 08:20 PM
well my vtec solenoid gasket is leaking, so i guess it should be the #14 right?
Sic_DA_Nine
Feb 1, 2008 09:30 AM
integraRS-T
Nov 27, 2007 09:36 AM
ITR32
Jul 27, 2007 06:09 AM
plikit
Jun 4, 2007 06:56 PM
